Engine not so smooth
Old Jul 10, 2007 | 07:52 PM
2003SE
My max has 149K miles on it and I'm the original owner. While in Park, I hit the gas, I don't feel or should I say hear the car as smooth as it used to be. Tranny problem? Any suggestion?
Sorry for not being able to clarify this any better.
Old Jul 10, 2007 | 07:54 PM
NmexMAX's Avatar
dot dot dot ...
Any MIL codes? How's the rear motor mount?
Old Jul 10, 2007 | 07:57 PM
2003SE
mil codes? I don't know anything about motor mont? Will you please explain?
Old Jul 10, 2007 | 08:04 PM
NmexMAX's Avatar
dot dot dot ...
Is your service engine light on? If so, it could be pointing to a malfunction which would affect driveability.
As far as the motor mount is concerned:
http://forums.maxima.org/showthread....ht=Motor+mount
Old Jul 10, 2007 | 09:12 PM
kramarz99
just a quick question, how does bad motor mount effect motor,tranny and how can I tell that they need to be changed out?
thanks
Old Jul 11, 2007 | 12:54 AM
getbigtony's Avatar
if anything, it'd be your torque converter; how would tranny do with engine power in park?
your engine wouldn't be as smooth because it might have carbon buildup all over the place, which is normal
Old Jul 11, 2007 | 06:10 AM
NmexMAX's Avatar
dot dot dot ...
All these suggestions are a touch far fetched. I still think my considerations are more appropriate and relative. Eliminate the small/easier items before going to extreme.
Old Jul 11, 2007 | 01:01 PM
2003SE
Thanks Darcy.
SES is not ON. I had the hood open while in park and when I hit the gas, I hear the engine and it doesn't sound as healthy as it used to. I understand the car has 149K miles.
How about using premium motor oil specially formulated for higher-mileage cars -- such as Castrol GTX?
Do you recommend any off the shelf product from AutoZone to reduce engine noise?
Old Jul 11, 2007 | 02:15 PM
Gle03Max's Avatar
If its not in gear it wouldnt have anything to do with your transmission. Try doing a fuel systems cleaning, or what a lot of people like to do on hear seafoam.
Old Jul 11, 2007 | 02:42 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by 2003SE
Thanks Darcy.
? ?? ? ? ? ?? Strange, that's my cars name
Old Jul 11, 2007 | 02:52 PM
2003SE
My bad...
Old Jul 11, 2007 | 03:03 PM
2003SE
Thanks Derek.
I'll try one of those fuel system cleaners.
BTW--I've always wanted an air intake. How does your Maxima run with the air intake you got?
Old Jul 11, 2007 | 03:59 PM
Gle03Max's Avatar
No problem. Make sure with the cleaners its actually something for the engine not just your typical gas tank additive.
My intake is great. I just switched over from the apexi air to the k&n and I think the K&N runs much better and is bigger. Its cheaper to so id recommend you save the money and get the K&N.The intake has a low whistle and past 4k it growls mean and makes the 3.5 sound great.
Old Jul 11, 2007 | 04:18 PM
2003SE
[QUOTE=Gle03Max]No problem. Make sure with the cleaners its actually something for the engine not just your typical gas tank additive.
What brand is recommended for our cars?
Old Jul 11, 2007 | 04:23 PM
Gle03Max's Avatar
[QUOTE=2003SE]
Id buy seafoam from autzone. ( $5.99 if I remember correctly ) Then i would do half in gas tank and other half through brake booster vacuum line.
There is a video how to here - http://forums.maxima.org/showthread.php?t=508545
There is also other info in there.
Old Jul 11, 2007 | 05:45 PM
2002 Maxima SE's Avatar
How many miles on your spark plugs?
Old Jul 11, 2007 | 06:43 PM
2003SE
50K or 60K. Time to check those too. Thanks man.
Old Jul 11, 2007 | 06:49 PM
Teufelhunden's Avatar
thats pretty high milage for 03. out of curiosity, does your engine burn any oil?
Mar 12, 2020 12:06 AM
bumpypickle
Sep 19, 2015 01:07 AM
Violator
Sep 9, 2015 10:14 AM
dcardello
Sep 3, 2015 11:44 PM
