I believe '02 3.5 engine has Drive by Wire .. but
Old Jul 13, 2007 | 02:47 PM
Coupedncal's Avatar
what is the difference between drive by wire and throttle by wire that is say in Honda Odyssey? Could someone provide input? Is drive by wire also adaptable (learns driver's behavior and adjusts accordingly)?
Old Jul 13, 2007 | 03:30 PM
NmexMAX's Avatar
dot dot dot ...
I don't believe the FSM mentions anything of it.
Old Jul 13, 2007 | 04:13 PM
irish44j's Avatar
retired moderator
drive by wire just means that when you press the gas pedal, it transmits an electronic signal through the ECU to the throttle body, and a little motor moves the butterfly valve to allow air into the engine.
as opposed to a cable throttle, where there is literally a cable from the accelerator linkage directly to the throttle body, so your foot is actually opening the butterfly with its own power.
oh, and cable throttle means you can rev the engine from under the hood
Old Jul 13, 2007 | 04:20 PM
NmexMAX's Avatar
dot dot dot ...
That didn't help Josh. Read the ? again. I thought the same thing, but read it again and that was not what the point was.
HINT: Both systems he mentioned have the word wire in them.
They're the same thing, described in different words. The FSM mentions nothing of learning how a driver drives and does not adjusts TBW/DBW accordingly. It does re: fuel trims and AT shifting characteristics, but not TBW/DBW
Old Jul 14, 2007 | 12:35 AM
Coupedncal's Avatar
Very interesting. Thanks for the info. So it sounds like our 3.5 VQ35DE does adjust transmission shift points based on past usage.
Matt93SE
May 24, 2019 02:58 PM
schmellyfart
Sep 25, 2015 04:47 PM
conansriver
Sep 3, 2015 06:38 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
