Easy way to re-aim fogs?
Old Jul 21, 2007 | 06:34 AM
soundmike's Avatar
Very sound, Mike
Does anyone know how to easily re-aim the fogs? The way i've done it was to jack the car up, aim, bring the car back down and check where the light falls of on a mark i placed on the wall--then i repeat until i get it right.
Anyone have a better idea?
Thanks.
Old Jul 21, 2007 | 07:51 AM
misiek's Avatar
take out your headlights and do it while the car is on the ground..... theres more room that way and beats jacking the car up and guessing the whole time
Old Jul 21, 2007 | 07:14 PM
crispykid717's Avatar
Bigger than Jesus
^^^This is the way i did it last time I had to reaim them. Very easy.
Old Jul 22, 2007 | 01:20 PM
FanaticMadMax's Avatar
He's asking about the fog lights not the headlight, fog lights does not have aiming screws like the headlights. It's fixed, unless you removed your housing of the foglight in the first place and put it back, probably didn't re-inserted back correctly to seat in.
Old Jul 22, 2007 | 01:49 PM
ICELANDIC MAX's Avatar
I remember the back of foglight housing had the screw mechanism for light aiming the last time I had changed the bulbs. But that was about 4 years ago though so my memory may have deteriorated since then.
Old Jul 22, 2007 | 02:37 PM
soundmike's Avatar
Very sound, Mike
Thanks guys, i'll try that... seems simple enough.
Fanatic, perhaps with 2k1. On a 2k2 there is a screw in the back you can use to change the aim of the bulb.
Old Jul 22, 2007 | 05:37 PM
opanick's Avatar
I can verify on 2k2 and 2k3 there is an aiming mechanism
Old Jul 22, 2007 | 07:18 PM
DAP's Avatar
DAP
Going by your join date I'm assuming you have a 2000-2001
http://www.courtesyparts.com/instruc...ghtkit_06.html
2002-2003
http://www.courtesyparts.com/instruc...00002_pg5.html
Old Jul 22, 2007 | 07:39 PM
Teufelhunden's Avatar
you dont have to jack up your car. but you do have to take them out. theres really no easier way.
Old Jul 23, 2007 | 10:51 AM
SoulEater's Avatar
here is the simplest ways. turn your steering all the way to the right, if you want do the left side and so on for the other sides. Take off the plastic nut that's holding the spalsh guard from fender (you don't need to take off the whole spalsh guard. make sure the space is enough for your hand). then slide your hands with screw drivers.
Old Jul 23, 2007 | 11:30 AM
ColdSHO's Avatar
just take the headlights out, its not hard and there plenty of access to the alignment screw. use a nubby screwdriver, its easier that way. ive trid just about every way, and thats the easiest.
Old Jul 23, 2007 | 01:25 PM
Trurida18's Avatar
mine has a screw aimin mechanisim as well....thats what i did to re aim mine after i installed my HID's in my fogs
Old Jul 25, 2007 | 07:43 PM
tbombs32's Avatar
id say just take the headlight out...but which way would you point the fogs does this help alot?
Old Jul 26, 2007 | 04:12 AM
soundmike's Avatar
Very sound, Mike
I did it with the headlights out, it's still off a bit but better than before. I can't do this without lifting the car, if i did it from the ground, since the car is dropped.
Thanks everyone for your tips!
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
