Battery Relocation / True Cold Air Intake
Originally Posted by babyboyws6
why not just get a cattman intake instead of doing this?
im guessing people wanna be unique and clever... this is a very clever thing to do.. but, once again... why not just get a cattman ?
Originally Posted by NmexMAX
Meh thoughtz j00 had a modified E36 MAF?
IBlookslikeSRsfilter.
Nice thermostat there.
I gave him the filter he is using now since I never went to e36 maf. What is this thermostat you speak of?
IBmoddedZ33
Originally Posted by Orgullo
In the write up it was for the people that had the Injen intake. If you are fortunate enough to already have the Cattman then good on you. However to run a CAI with your Injen then you are going to have to do this. Or run it under your fusebox like some have done. Maybe people should read before posting and you would have seen this.
ummm it was a question .... sir
exactly so whats the point in saying maybe i should read something??
it wasnt called for
it wasnt called for
the point...if you had READ, the question was already answered
my exact question was asked and answered after i posted it. The topic of the Fujita was the only other one brought up. w/e thats done...
Now another question that wasnt asked... How vulnerable is this placement to water?
Originally Posted by E55AMG2
If you drive in deep water at WOT, you deserve to flood your engine. Dont drive like an idiot, and you wont have issues.
I make more power than all of you with my stock airbox.
After this setup is all said and done... would wrapping the piping up too keep it a lil more cool be an adequate move?? Cooler is better right?
First off, thanks for the excellent writeup here. It inspired me to buy a CAI and perform this mod. I did the battery relocation this afternoon so there would be one less thing I had to do when the CAI arrives. I was not able to follow your directions completely, maybe this is because you have a 2003 and I have a 2000. Anyway, when I tried to use the same battery tray holes as you show in the pictures the battery would press into the radiator hose so my try is at an offset a little offset, no biggie i guess. Perhaps once my intake comes I can get things straightened out. Everything looks nice and perpendicular in your photos. Good work.
He does make more....because he copied me
Originally Posted by DasYears
i just dont see proof. there are plenty of people here that make more than 248...the point: there was absolutely NO reason to post anything about having more or less power than others here, especially without data which he so highly regards
1) He's auto, so no...there arent
2) He was making a joke....you blew it out of proportion
3) He's got dyno runs, shoot him a PM
4) Don't whine in my forum, or I will send you on vacation.
i never whined. just said no data no care. if he wants to make rude comments to .org member make them in pm's, we dont need them here. and just because you have an auto with less hp than others with 6spds doesnt mean he has more power, just that he has an excuse to have less
It's crazy how fast a thread can get off topic.
RMH: I didn't assume that the tray would be that much different. However, if it is then all you would have to do is predrill the holes in the tray to line up with your existing holes. Just make sure that you put it in place to avoid hitting the radiator hose and not too far forward to hit the intake piping. Shoot me a pm with your pics and I'll see if I can help you out. If you need it.
just post em on here, even though it doesnt affect me i would like to see the difference too
That would make more sense lol. Post em up man...
Anyway here are some shots of my initial attempt at this battery relocation on a 2000.
You can clearly see how my battery is offset a little bit and that there is no extra room between the radiator hose and the bottom of the battery. Im gonna have to wait till I get my intake before i play with it any more, once I have it in hand I will have a better idea how things will fit over there.
I think once you move the stock intake out of the way you'll have to room to push it forward a bit. With that being said you should be able to just drill the holes on the tray to line up with the existing holes on the mount.
By the way... line the pics on top of each other instead of side by side.
ORGULLO__
Im definitely doing this mod once i get time. But if i wanted to use the K&N air filter instead of the apexi... you think it wouldnt be no problem... i mean i have no idea how much room you had left to spare using the filter you used
There is tons of room inside the fender. I think it's just a matter of measuring the amount of space you'll need to use the K&N. Turn your wheel to the right and pull the splash guard back. You'll see the amount of room you'll have to play with.
Good luck.
Good luck.
Ok, ok, let's let the thread get technical again.
