Battery Relocation / True Cold Air Intake
Old Aug 7, 2007 | 08:56 AM
  #121
tonynj1208's Avatar
wow came out nice
Old Aug 8, 2007 | 02:09 AM
  #122
maxximaa's Avatar
u drive your car when it rains? wont the filter get wet?
Old Aug 8, 2007 | 05:52 AM
  #123
babyboyws6's Avatar
dude that question was answered twice already... go through the others posts before asking a simple question like that.
To answer you str8 up... if you drive into a pool than yeah.... or if your an idiot and drive into a big *** flood.... in other words... dont drive like a moron in those conditions and you will be fine
Old Aug 8, 2007 | 07:11 AM
  #124
LatinMax's Avatar
I have a CAI and have never had any problems. I do not drive thru mud puddles... like to splash someone. That will cause problems. I only know of one person that drove thru a deep mud puddle fast and ended hyro locking his motor and basicly blowing it up.
Old Aug 8, 2007 | 07:35 AM
  #125
babyboyws6's Avatar
what cai do you have??
Old Aug 8, 2007 | 08:20 AM
  #126
LatinMax's Avatar
Home made with a HUGE K&N filter Write-up
Old Aug 8, 2007 | 08:56 AM
  #127
E55AMG2's Avatar
Wat
The filter is in the fenderwell, completely sheilded from water.
Old Aug 9, 2007 | 05:28 AM
  #128
TDotMax's Avatar
Ok so it looks like I will attempt this mod. After researching (Now donating ). I realized a lot of my mods I'm doing is going to take away from the my low end. If this CAI setup can restore a couple HP down low it maybe in fact worth it for me. Look forward to see pics of how the 5.0 setup worked out.
BTW, is the Injen 3"?
Old Aug 9, 2007 | 06:35 AM
  #129
Orgullo's Avatar
$$ Ballin on a Budget $$
The injen is 3", as far as the 5th gen I think it's the same way with the exception of the midpipe. You will need a midpipe that will accomodate the vaccum lines etc...
In his pic he still has his stock air box in and I think that is what's preventing him from putting the battery straight.
Old Aug 9, 2007 | 06:47 AM
  #130
TDotMax's Avatar
I'll be using my stock accordian and resonator so I'll just need the piping from the maf to the filter.
Old Aug 9, 2007 | 07:18 AM
  #131
babyboyws6's Avatar
asuming you have cattman headers and the the cattman cat back exhaust... already running a injen Wai... did this conversion so now they have a magical injen cai. also a SACF.... how much base hp would be seen and about how much whp could be seen?...
dynos would be great 2!!
Old Aug 9, 2007 | 07:25 AM
  #132
TDotMax's Avatar
huh? Did you read the thread? I asked about dyno's, look at page 2! You will not see the advantages of this on a Dyno. You see extra numbers for a WAI setup as the cooler fan is blowing on the intake.
Old Aug 9, 2007 | 08:46 AM
  #133
NmexMAX's Avatar
dot dot dot ...
The real item here would be IAT's. 84% of the org wants to know these numbers, But 98% of those 84% do not have the capability to log such parameters. 38% have access to a TC/logging software etc, but only 12% actually have both the desire and equipment.
And you're right, as E55AMG2 has pointed out, CAI gains aren't really noticed on DJ dynos. The come into play only when it really counts (traffic/hot day). Cruising (35-75+) speeds my car sees ~ +5-10ºF above ambient. I get a light and it goes up to ~ 30-45º above ambient. I have a stock airbox, so no it's not a true CAI, nor do i have access to one.
I do a lot(80%) of highway driving so I really don't see that much of a need for such a device. That and I cannot stand the noise.
If you're worried that much about losing low end power, why not swap your car to a 5MT? It would cost roughly the same amount as cams and such, but would eliminate that auto lag that horribly plagues the Power rodlessVQ30DEK/4AT/A33 combo.
If you're like me and you do the majority of your driving on the highway, why not, but it seems as if lately you've been worried bout said low end losses. so I suspect, that you may in fact do your share of city driving.
Also, for arguments sake, and not that it matters at this point nor in this thread at the moment, but the Injen is not true 3" ID, 3" OD IIRC.
***EDIT
In your situation, it will be give or take since you do not have CVTC. So your option are limited. At this point, you have 2 options for noticeable gains, get CVTC( not an easy task), or larger cylinders(not a cheap task) .
Of course there's always lighter wheels/brakes/weight reduction/higher stall
You can try the ub3r MAF mod since I stand by it re: gains in the low end/part throttle if done correctly, but my car is different than yours so, I suppose take that with a grain of salt.
Old Aug 9, 2007 | 08:56 AM
  #134
MyBlue02's Avatar
so who's the fujita lab rat now that they are $189 shipped?
Old Aug 9, 2007 | 09:10 AM
  #135
TDotMax's Avatar
5-Speed swap will hopefully be done this winter, hard to say with wedding plans coming up as well. But even with the 5-speed, I'm trying to keep some low end regardless.
Old Aug 9, 2007 | 11:05 AM
  #136
Orgullo's Avatar
Just so you guys know, IF, you decide to do this mod but don't have the injen intake it can be done with the 95-99 "CAI." I got this elbow from a 97 and actually it has a better bend to it then the Injen.
You can get it here on flea bay for next to nothing. The only thing is that the midpipe is made for that year. Either plug the extra holes on the midpipe or source another one made for our year. ( 02/03 )
Another option, go to Pepboys and get the straight piece of piping, drill a hole out and place your vaccum line in. Make sure to seal it up.
Note: This midpipe will work for the ( 00/01 ) However, not sure about the length on the midpipe, since it will have to extend long enough, with the maf, to let the elbow reach the hole.
http://cgi.ebay.com/ebaymotors/Nissa...QQcmdZViewItem
Old Aug 9, 2007 | 11:17 AM
  #137
DasYears
for that price, it must last at least a week
Old Aug 9, 2007 | 11:21 AM
  #138
Orgullo's Avatar
It's aluminum piping, it'll last about as long as your car so long as you take care of it. It's aluminum, not plastic.
Old Aug 9, 2007 | 12:05 PM
  #139
Orgullo's Avatar
Just some pics of the 4th gen piping. It has a curve on the piping so it's a better fit with it. Definitely recommend it if you don't already have an elbow. Only need the larger piping
Old Aug 9, 2007 | 03:03 PM
  #140
TDotMax's Avatar
What an idiot though, how does he justify $135.00 shipping to Canada?
I'm just using my stock accordian and resonator, I'm sure to find the elbow locally.
Old Aug 9, 2007 | 03:57 PM
  #141
Orgullo's Avatar
$135.00 for shipping to Canada? Damn...
For the most part all of these are priced around the same range so check around. State side people... this is a steal.
Old Aug 10, 2007 | 07:57 AM
  #142
DasYears
needs to be min of 3" ID or its useless to me
Old Aug 10, 2007 | 08:12 AM
  #143
Orgullo's Avatar
Well get one fabbed up and your straight...
Old Aug 10, 2007 | 08:19 AM
  #144
E55AMG2's Avatar
Wat
3" ID is useless to your car too, unless you do a big MAF
Old Aug 10, 2007 | 09:06 AM
  #145
DasYears
i may or may not have a 75mm maf tube with plans to go bigger...
Old Jun 30, 2008 | 07:31 PM
  #146
NismO2max's Avatar
Wow, another thread that has become USELESS w/o pics.
Where did they go?
Old May 24, 2009 | 09:08 AM
  #147
nishfish871's Avatar
This mod is well worth it and don't know why a lot of people don't to it. Took me 3 hours and I installed the Altima se-r injen cai. Fits perfectly.
Old May 24, 2009 | 11:05 AM
  #148
Tippy Toes's Avatar
Like to do this mod but it will be when I get into doing mods in the bay. No dynoes were ever produced from anyone dynoing (anything) from what they had to this. Alot of members or a few anyway said that stock airbox gave more power..
Nice write up from 2 years ago though and like I said eventually would like to do this..
Old Nov 17, 2009 | 04:44 PM
  #149
InfiniwhiptinitiII's Avatar
This is how you keep great power, smoothness, and beautiful sound.
this may sound stupid but what exactly ami looking at here?
Old Dec 30, 2009 | 12:30 PM
  #150
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
Well this thread is nearly useless now without pics
Old Dec 30, 2009 | 01:00 PM
  #151
Rochester's Avatar
If you look at the original posts, you'll see the OP's images are hosted at http://memimage.cardomain.net. I think "memimage" is a subdomain on a separate server for images, because cardomain.net is up.
My point being: try again later, Sparks, and the images might show up.
Old Dec 30, 2009 | 02:34 PM
  #152
killer00's Avatar
This guy didn't post pictures on the process for this setup. I now think its trash.
Old Dec 30, 2009 | 03:56 PM
  #153
He did originally... now they aren't working. The reason it becomes much less useful without them is because almost all of his steps are describing things that are circled or shown in the pictures. But go ahead with your facetious remarks
Old Dec 30, 2009 | 04:34 PM
  #154
killer00's Avatar
I take my comment back. Im glad that the pics were posted. stupid me to not think about that.
Old Jan 4, 2010 | 02:52 PM
  #155
LatinMax's Avatar
here is my write up fot ,oving the batt. http://www.cardomain.com/ride/286919/5
Old Jan 19, 2010 | 04:46 PM
  #156
914Max914's Avatar
the hell are the pics!!!!!!!!!!!!! >=\ lol
Old Apr 23, 2010 | 01:21 PM
  #157
Orgullo's Avatar
Thread has been updated with pics... Didn't know people were checking this thread out still.
See ya.
Old Apr 23, 2010 | 07:06 PM
  #158
McSteve's Avatar
Thanks so much!
Moderators, can we get this added to the stickies in the how-to.s?
Old Apr 26, 2010 | 06:26 AM
  #159
Orgullo's Avatar
This was stickied at one time. Not sure why it was removed. I think Ice core did a write up so they bumped this one and posted his. Just sayin
Old May 25, 2010 | 05:31 PM
  #160
Rods03Max619's Avatar
Originally Posted by Network13
A Neon on a Maxima scene with some BS!!
