ABS TCS SLIP lights are on
Old Jul 22, 2007 | 07:59 PM
romefolk's Avatar
here we go!
I have 2001 Infiniti I30 and I have a problem... Lights for ABS + TCS + SLIP are on and they wont go off.
I was driving on Friday night, i hit a pothole the size of the grand canyon. but the SLIP ABS or TSC didnt come on.
I was doing my HID retro on Saturday..alll day. i had to jack the car up to get under it and things like that.
i put everything back together, started the car and all three of those lights were on..
Has anyone ever experienced this? what should i do?
HEeellllppp!
Old Jul 22, 2007 | 08:47 PM
s1mply_v's Avatar
yea i have the same problem..
I have an 01 SE Max.. occaisionaly my ABS TCS and SLIP lights come on at any random moment no matter the road conditions.. and most times they work perfectly, TCS turns on/off fine and ABS SLIP lights arent on..
its wierd and i dunno my the problem to mine either.. I WOULD LIKE SOME ANSWERS 2 BUD! lol
mayb its juss the mood of my car? :P
Old Jul 22, 2007 | 09:30 PM
ktranne's Avatar
NOOB
bad coil(s)...
Old Jul 23, 2007 | 12:08 PM
roclucky1's Avatar
Originally Posted by ktranne
bad coil(s)...
I had same problem. Took it to the dealer had it scan and it was the rear speed sensor.
Old Jul 23, 2007 | 02:42 PM
wngan9447's Avatar
Chicken Feet Croo!
http://forums.maxima.org/showthread....light=TCS+Slip
Coils all the way.... i changed all 6 when mine went. Unfortunately the code didn't give me a specific cylinder so I didn't have much of a choice. I still have the old coild sitting in my garage.
Old Jul 23, 2007 | 09:17 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
He doesn't have a check engine light on, so how can it be coils ?
Old Jul 24, 2007 | 08:58 AM
wngan9447's Avatar
Chicken Feet Croo!
Good point... i read through that quickly and didn't pick that up...
Speed sensor for my second guess
Old Jul 24, 2007 | 09:22 AM
nlmaxima's Avatar
I checked the codes in my 2000 Maxima by grounding pin #8 in the DLC with the key turned ahead and got flash codes 12 and 21. 12 is that it is doing a test and 21 is a problem with R/F sensor. I have a sensor on the way and I hope it fixes the problem.
Old Jul 24, 2007 | 07:38 PM
romefolk's Avatar
Yeah, I've been driving it still, lights still come on. do you think the regular scanner will read the codes?
Old Jul 24, 2007 | 07:57 PM
sympatico's Avatar
When I had a bad coil, my SLIP, TCS, and ABS light came on a long with the CEL.
Old Jul 25, 2007 | 02:59 AM
nlmaxima's Avatar
I don't think so. I tried a Geniuses and the newer SnapOn scan tools, they couldn't read the ABS on a Canadian 2000 Maxima SE. Yours could be different.
Old Jul 25, 2007 | 08:17 PM
s1mply_v's Avatar
hmm.. well my CEL don't come on eithr.. and another question.. why would ABS apparatus be related to coils and ignition??? maybe you guys are talkin about a different coil?
anywho.. my car spits out the ABS, TCS, and SLIP once in a while.. i think it could be the speedsensor too.. i wanna find out the problem to mine 2 cause its annoying
Old Jul 30, 2007 | 02:48 PM
MacGarnicle's Avatar
unfortunately you'll have to take it to the dealer to get the code pulled. There's a way to do it yourself, but you'll have to search for it. Dealer will charge you an arm and a leg for the sensor, so call Dave B.
If the lights come on intermitently, may not be the sensor. Could be part of the wiring or something else. Unfortunately its hard to troubleshoot because a failure of any part of the system throws the same code. When my sensor went the lights would go on and off for a few weeks. Eventually it just stayed on. Could be your sensor slowly on its way out.
Old Jul 30, 2007 | 04:10 PM
roclucky1's Avatar
The dealer will charge u 92.85 for a sensor.plus 85.00 for a abs scan.plus tax.
Old Jul 30, 2007 | 06:05 PM
merlin123's Avatar
I had a same problem on 2000 maxima, my ABS lights and TCS and SLIP come on, but no check engine light. It turned out to be alternator. Before I had a problem with coils then I would get TCS and SLIP plus CEL but no ABS.
Old Jul 30, 2007 | 07:12 PM
ABS system won't throw a code a normal ODBII reader can read.. if you get a code, it's not ABS. Try to scan it and go from there.
Old Jul 30, 2007 | 07:14 PM
Depends on your area I suppose. My dealer wanted $500 for the part. Cost me around $120 with tax to get the bugger scanned. Had to pay for their general 'diagnostic'. Shoulda just talked with one of the mechanics, but I had some other things that needed 'diagnosing' anyway - made them work for their hour
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
maximusrising
Sep 2, 2015 09:55 AM
