Keyless entry?
Old Jul 31, 2007 | 12:17 PM
AE_Racer's Avatar
Keyless entry?
I have an 01 base? model max and I was wondering if they all have keyless capability from the factory? I got my car used and I did not get a keypad with it, but I was wondering if I could just buy a remote and program it and it would work? thanks
Old Jul 31, 2007 | 12:21 PM
Rydicule's Avatar
Don't you know who I am?
Yes. You will have to have it programmed, but they all should have keyless entry capability. Talk to your local dealer, not sure how much it would cost for programming.
Old Jul 31, 2007 | 12:25 PM
AE_Racer's Avatar
awesome, thanks for the quick answer bro
Old Jul 31, 2007 | 12:41 PM
02Maximan's Avatar
Actually all you have to do is make sure your car is setup with keyless (which I'm sure it is) and go on ebay and find a remote and program it yourself. i bought one off there just recently for $15 shipped and programmed it myself. Its really easy. DON'T take it to the dealer cause they will charge you like $40 to do something you can do in like less than a minute. One place that has instructions is www.programyourremote.com
Old Jul 31, 2007 | 12:48 PM
Eastern's Avatar
^^ Wish I knew that before I had mine programmed...
Old Jul 31, 2007 | 12:56 PM
AE_Racer's Avatar
thanks maximan
Old Jul 31, 2007 | 12:57 PM
DrunkieTheBear's Avatar
Turbo'd Saab
schweet now i can jack peoples cars
Old Jul 31, 2007 | 01:08 PM
02Maximan's Avatar
Yeah I really kicked myself when I found out how easy it was to do it cause I had taken a different remote to the stealership earlier and had to cough up $40. I was like no more of that!!
Old Jul 31, 2007 | 01:13 PM
Turbo'd Saab
could this trick work to just say refresh the key fob, cause i've replaced the batteries on all three of mine but sometimes they refuse to work and then sometimes they will work from the forth floor in the building i work at which is about 2 football fields away
Old Jul 31, 2007 | 04:00 PM
rmaxima02's Avatar
Program it yourself. With the remote and programming it would cost you like $120 at the dealer. RIP OFF!
TRY to program it yourself! Much easier, cheaper, and FASTER!!
Old Jul 31, 2007 | 07:17 PM
bigj01AE's Avatar
Are there special remotes for the AE cars, or are all of them generic? I also bought mine used without remotes and hate the fact that there is no door key on the passenger side. Thanks.
Old Aug 1, 2007 | 09:27 PM
Swiyzee's Avatar
Maxipimp
AE's use the same keyfob as the other 2k-2k1's
Old Aug 3, 2007 | 04:05 AM
TDotMax's Avatar
I'd go back to the seller and question where the key fob is. My buddy has a 00 GXE and it is equppied and came with 2 fob's.
Old Aug 3, 2007 | 05:24 AM
SilverGLE's Avatar
I'm watching you, boy...
A lot of times people will loose them between their house and the dealer... I only got one (flaky) remote with mine. But I bought another off Ebay and it works like a charm!
Old Aug 6, 2007 | 07:11 AM
dat01max's Avatar
bought one off of ebay and it wrked fine
Old Aug 6, 2007 | 11:24 AM
macnolias's Avatar
What do you have to do to program the ebay remotes?
Old Aug 7, 2007 | 02:14 PM
AE_Racer's Avatar
Old Aug 15, 2007 | 10:11 AM
KL77's Avatar
I bought a replacement remote off Ebay for my 2k SE because my original remote stopped working. The original remote would lock the doors and open the trunk, but wouldn't unlock the doors. The new remote I received suffers the exact same problem. I programmed it correctly, but it also will not unlock the doors but does lock them and do the trunk. Any ideas?
Old Aug 16, 2007 | 02:53 PM
SilverGLE's Avatar
^ You can open up the remote and try to clean off the rubber insert with soap and water, as well as take a toothpick to the switches on the printed circuit board.
Old Aug 16, 2007 | 02:59 PM
AE_Racer's Avatar
was the replacement a new or used remote?
do the doors unlock with the switch from the inside?
Old Aug 16, 2007 | 10:08 PM
Trurida18's Avatar
ill be damned if i were gonna pay the dealership 80 bucks for a remote with programming. I purchased the remote from Ebay from one of the Nissan OEM vendors (Calsonic Kansei Corp) and i searched the net and found the instructions.... I got the remote from Ebay for 16 bucks shipped. However my remote is modeled after the 2k4 remotes
my new one looks like this........
Old Aug 16, 2007 | 10:09 PM
Trurida18's Avatar
u can also use rubbing alcohol on the circuit board, if its pretty dirty....Alcohol has no operating effect on circuit boards. U can soak an entire processor in Alcohol, let it air dry for an hour, and ITLL BE GOOD AS NEW.
Old Aug 16, 2007 | 11:11 PM
SilverGLE's Avatar
Hmmmm... I'll have to remember that...
Old Aug 17, 2007 | 12:46 AM
KL77's Avatar
Used, "guaranteed to work" (he checks them before shipping and has decent feedback on Ebay). The door unlock button on the inside does work. You thinking bad BCM?
Old Aug 17, 2007 | 11:14 AM
J-Rod's Avatar
I need a keyless entry fab for 2000 max anyone have a extra they would like to part with?
Old Aug 17, 2007 | 02:02 PM
SilverGLE's Avatar
Whatever you do, make sure to match the FCC ID on your old remote with the one you want to buy. The FCC ID must match for it to work.
Old Aug 17, 2007 | 02:19 PM
Trurida18's Avatar
DUDE JUST GO TO EBAY...u can get one for 10-15 bucks shipped...JUST BE SURE TO LOOK AT THE FCC ID's like SilverGLE said
they must match "AT LEAST" the first six characters
Old Aug 17, 2007 | 04:19 PM
J-Rod's Avatar
Ok cool. What about the programing?
Old Aug 17, 2007 | 05:41 PM
02Maximan's Avatar
Can you please read through the whole thread? Theres plenty of info in here already if you will only READ!
Old Aug 17, 2007 | 06:03 PM
mist max2000's Avatar
hey trurida-- that 5.5gen remote works fine on the on ur 5th gen and u programmed it yourself?,.. just curious cuz that remote is 10x nicer then the crappy 5th gen one and i would like to give it a shot.. thanks man..
Old Aug 17, 2007 | 06:08 PM
J-Rod's Avatar
careful tough crowd....
Old Aug 17, 2007 | 09:22 PM
Trurida18's Avatar
yup, i programmed it myself...and it definately works , GO AHEAD AND GIVE IT A SHOT BRO! I got it from EBAY......youve got a 2000, so check the FCC ID on the back of your remote, and try to look for a manufacturer from one of the OEM vendors for the NISSAN REMOTES.....But your right, the regular 5th gen remotes are UGLY
Old Aug 17, 2007 | 09:24 PM
Trurida18's Avatar
AE RACER, ALREADY posted this link further up in the thread
but the technique mentioned here is the right one indeed.......ITS A WALK IN THE PARK, and can literally be done with your eyes closed...So dont feel discouraged
ah2002
Mar 9, 2016 01:42 PM
flu2000
Sep 14, 2015 12:34 PM
videomano
Sep 8, 2015 03:28 PM
Hailstatejig
Sep 2, 2015 06:52 AM
