Pedal Learning Procedures Q
Old Aug 1, 2007 | 08:28 AM
Prophecy99's Avatar
Originally Posted by HOWTO Thread
Accelerator Pedal Release Position for 2K2+
Quote:
Accelerator Pedal Release Position Learning
Operation Procedure
1. Make sure that the accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds.
May I ask what all this does exactly, or any of the pedal timing procedures? Does it allow the owner to change things such as when the pedal does what?
Or is it simply just for checking/fixing codes, reseting ecu etc.
TIA
dont ignite me
Old Aug 1, 2007 | 08:44 AM
wyche89's Avatar
i have no idea... but it sounds like somebody could do it by accident
Old Aug 1, 2007 | 09:38 AM
nk2k2's Avatar
this was quoted off of titantalk.com :
I think it's important to do the learning procedures periodically, as it basically recalibrates the electro-mechanical positioners, namely the throttle valve positioner and the accelerator pedal positioners. After some use, these things get a little out of whack, and get kinda lost. This can cause problems like loss of power and idle issues. This method restores the proper min/max position voltages that the ecu sees from them.
i think it sounds about right.
Old Aug 1, 2007 | 09:47 AM
Trurida18's Avatar
i should have purchased a 2k2 or 2k3,
Old Aug 1, 2007 | 11:29 AM
Prophecy99's Avatar
Seems to be strictly ECU coordination then.
Old Aug 1, 2007 | 11:31 AM
SoonerFan's Avatar
Cletus
this has to do with the throttle body and is called "throttle position sensor learning"
you use the pedal to do it...but has nothing to do with the pedal position
ef9
Oct 4, 2015 08:43 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
