Just bought a max and inherited problems
Old Aug 3, 2007 | 09:47 PM
Reket's Avatar
I just bought a maxima 2002 vq35 6 speed from a city 400 miles away from where I live the car drove perfect on the test drive and I checked it out no leaks get good gas mileage so its not burning oil with 60,000 miles.
When I got home a noticed a scraping noise from the front left tire when I brake and turn the steering wheel.
and squeeking noise from the engine at idle (a belt I prosume)
any insight on what these might be will be gratefully appreciated.
I am taking the car to my mechanic on Sunday but I need to drive around on saturday and was wondering if any of this was dangerous.
Old Aug 3, 2007 | 10:02 PM
wyche89's Avatar
that scraping noise is probably your brakes... i say replace your brakes and your belt and you're good to go... those problems don't sound serious enough to regret purchasing the car
as far as the oil burning issue... i dont know cause i don't have a 3.5.. but you may not notice that until you've driven the car for about a month or so based on other members' testimonies
Old Aug 3, 2007 | 10:17 PM
Reket's Avatar
I hope that all I will have to do, thanks for the response
Old Aug 3, 2007 | 10:19 PM
wyche89's Avatar
no prob.. you might not even have to replace the belt.. check it to make sure it's the correct tension because that can caust a squeal also
Old Aug 3, 2007 | 11:04 PM
Trurida18's Avatar
do you get the noise when you brake normally? or is it always strictly, while braking and turning?
Old Aug 3, 2007 | 11:10 PM
SoonerFan's Avatar
Cletus
since the car has 60K miles, I would recommend changing the belts. if you look, they are probably cracked.
Old Aug 4, 2007 | 12:56 AM
MaxBoost925's Avatar
Drug Money
scraping noise? Brake dust shield.
Old Aug 4, 2007 | 01:57 AM
SoonerFan's Avatar
Cletus
Old Aug 4, 2007 | 02:05 AM
Drug Money
Originally Posted by soonerfan
Org vice squad saves the day again!
Old Aug 4, 2007 | 02:14 AM
Fantomas's Avatar
Scraping noise might also be a wheel bearing. If you take it in to your mechanic ask him to check for that, unless he's a typical mechanic if you mention a problem he'll find 15 ways to screw you...
Old Aug 4, 2007 | 02:16 AM
Drug Money
Good point. Lift up your car and try to wiggle the wheel - if there's play, its your bearing.
Old Aug 4, 2007 | 01:41 PM
Reket's Avatar
Cool guys thanks, the mechanic is a buddy of mine so he wont screw me, but I love this org always helpful, thanks guys
Old Aug 5, 2007 | 07:14 PM
Reket's Avatar
So, Fyi for everybody got the car looked at and it the belt needs to be tightened and I need to change the bearing on the right front wheel
Old Aug 5, 2007 | 07:36 PM
spdfreak's Avatar
Welcome to the 5th gen family!
I would suggest that you go through a full fluid change (engine and transmission) and do the typical maintenance thats needed on a car of that age and milage.
Good luck with the new car!
Old Aug 5, 2007 | 08:05 PM
wyche89's Avatar
maxima.org saves the day once again
Old Aug 6, 2007 | 07:02 AM
Prophecy99's Avatar
@ what mileage are you advised to change belts? I didnt think it was that early...
Old Aug 6, 2007 | 07:04 AM
SoonerFan's Avatar
Cletus
so a FULL fluid change is only the engine oil and tranny fluid
pretty sure there are other fluids in the car
Old Aug 6, 2007 | 06:05 PM
lalaMAX's Avatar
P/S fluid, break fluid, engine oil, ATF, all belts, check breaks...i think daz it...
Old Aug 6, 2007 | 07:08 PM
Will's Avatar
The driver side wheel bearing seems to not last very long. I just got an '03 two weeks ago, and mine had to be replaced too under warranty from the previous owner at around 55K.
I too am monitoring my oil levels every few days for the dreaded engine oil burning problem. So far so good, though the ATF dipstick is just ashard to read as the oil dipstick.
tsi6001
Oct 3, 2022 10:23 PM
stromm
Aug 27, 2015 04:13 PM
Samedi
Aug 13, 2015 04:05 PM
erniel
Aug 8, 2015 09:32 AM
