Car will not start....help needed!
Old Aug 21, 2007 | 04:45 PM
The Law's Avatar
I R The Law
Its a vq30. The car very seldomly start but when it does start it only stays on for 30 seconds or less. Pulled out the coilpacks and put on old ones and still have the same result. Also pulled out the front spark plugs and they are fine. I also unplugged the maf and 02 senor with the same results. Vehicle has fuel in it. Basically when you try to start the car, the engine will turn over but will not ignite. Any help is appreciated.
Old Aug 21, 2007 | 05:26 PM
MaxBoost925's Avatar
Drug Money
It's my car btw.
I think it could be this way because 2 or more of the coilpacks are fried. I think If 2 or more don't work, the engine doesn't fire.
Old Aug 21, 2007 | 07:04 PM
Drug Money
Another member said it might be:
1) Fuel pump
2) Crank Position sensor.
Old Aug 21, 2007 | 07:17 PM
irish44j's Avatar
retired moderator
sounds like your fuel pump is gone.....I would check that first and go from there.
maybe it's not a VIP fuel pump (sorry, I had to! )
Old Aug 21, 2007 | 07:19 PM
Drug Money
wow ok lol.
I didn't flaunt it in a while........ anyways.
Yeah it starts up sometimes but rarely. I thought our fuel pumps don't die like that.
Old Aug 21, 2007 | 07:24 PM
irish44j's Avatar
retired moderator
Originally Posted by MaxBoost925
wow ok lol.
I can recall a couple of cases, but you are correct, it's not a common occurence. That said, any part can "die" under the right circumstances. F/E, it could be something as simple as a loose or failing electrical connection to the fuel pump.
There are certainly other things that could cause this problem, but fuel starvation seems like the most likely culprit from what you describe.
Old Aug 21, 2007 | 07:52 PM
AceofSpds's Avatar
wat
Has it thrown any codes yet?
+1 on a fuel issue though
Does it just cut off or slowy die?
Old Aug 21, 2007 | 08:08 PM
Drug Money
Codes I havn't scanned yet. I'm sure there has to be a code.
Old Aug 21, 2007 | 08:25 PM
Teddie18's Avatar
Let me know what the codes are and I'll most likely be able to tell you what the cause is and how to diagnose and repair the problem.
Old Aug 21, 2007 | 08:36 PM
Drug Money
http://forums.maxima.org/showthread....ghlight=walbro
I came across this thread looking up Walbro pumps. It was never fully answered.
Old Aug 21, 2007 | 08:48 PM
AceofSpds's Avatar
wat
You try using starting fluid? That will def tell you if you do or dont have a fuel issue.
Old Aug 21, 2007 | 08:52 PM
Drug Money
Man I will never use that stuff in my car - we're not carburated and that fluid can damage sensors.
Old Aug 21, 2007 | 08:54 PM
AceofSpds's Avatar
wat
Ive never had a problem w/ it, ive always sprayed it down the TB though. But then again most of the FI cars ive used it on are 10 yrs older than 5th gens.
Old Aug 21, 2007 | 09:27 PM
Drug Money
Here's another question:
If I were to replace the pump, filter, and o-ring, which Walbro pump do I buy for a 2000?
I want a 190lph.
Old Aug 22, 2007 | 10:43 AM
Drug Money
bump - what model Walbro 190lph pump do I use?
Old Aug 22, 2007 | 11:16 AM
djfrestyl's Avatar
Suspension Yoda
By any chance do you have any aftermarket alarm or remote start?
Old Aug 22, 2007 | 11:40 AM
Drug Money
No, all stock keyless entry. I don't think that'd be the culprit. Good point though.
Old Aug 22, 2007 | 12:04 PM
djfrestyl's Avatar
Suspension Yoda
You'd be surprised. Mine ended up being a combination of a dying battery, and then the alarm required a tachometer re-learn.
Old Aug 22, 2007 | 12:30 PM
Drug Money
Fuel pump fuse is good.
Old Aug 22, 2007 | 12:32 PM
Drug Money
Another member said that it could be clogged fuel filters
...Is there a fuel filter in the engine bay? He told there there is one if you follow the fuel lines.
and he also said that our cars can run with 4 cylinders but would be rough as hell.
Old Aug 22, 2007 | 12:49 PM
Bufflomike's Avatar
Sexier Than Simpson
Its in the tank, there is a how to in the stickies
Old Aug 22, 2007 | 12:58 PM
Teufelhunden's Avatar
fuel filter is underneath your back seats along with the fuel pump.
Old Aug 22, 2007 | 02:40 PM
Drug Money
I know about the in tank pump and filter, but he said there was another one in the engine bay - just making sure.
Old Aug 22, 2007 | 02:42 PM
Drug Money
I pulled 5 codes out of my car that don't really help me:
1) P0141 Rear o2 sensor heater bank 1
2) P1401 EGR temp sensor
3) P0100 Mass airflow sensor
4) P0161 Rear o2 sensor heater bank 2
5) P1401 again
I don't have secondary o2 sensors because I have headers and I don't have a simulator plugged in.
I removed my EGR so that's normal.
I have an updated MAF that I unplugged just to get the same results - no ignition.
Teddie18's Avatar
The only filter is in the tank.
Old Aug 22, 2007 | 02:44 PM
a_prince1's Avatar
Try turning your igniton to the on position and see if you can hear the fuel pump kick on. If you can hear the distinctive "whirrr" sound then your pump is fine.
Then i would look into the crankshaft position sensor.
Old Aug 22, 2007 | 02:46 PM
Drug Money
I tried that - it whirrs most of the time.
Old Aug 22, 2007 | 02:56 PM
a_prince1's Avatar
From the 5 codes you pulled t my knowledge none of those should cause a "no-start" situation.
If your fuel delivery is fine then it has to do with electrical. That will include anything from coils, plugs, injectors.
Did you try putting in some good injector cleaner?
Old Aug 22, 2007 | 02:58 PM
Drug Money
I just tried that before posting - Chevron fuel system cleaner concentrate - I dumped the whole bottle in there.
Old Aug 22, 2007 | 03:56 PM
meccanoble's Avatar
Sports Button FTW
my car stopped starting last night all of a sudden and I'm worried my fuel pump may be bad. I looked at following thread discussing how to change filter but the pictures are gone and I get lost without them. Any one have details on how to change fuel pump? The thread I found was:
http://forums.maxima.org/showthread.php?t=276627
Old Aug 22, 2007 | 04:13 PM
Drug Money
Look at this one:
http://forums.maxima.org/showthread.php?t=314172
Old Aug 22, 2007 | 04:22 PM
meccanoble's Avatar
Sports Button FTW
I found this write up for 02-03 maxima's. Everything looks very similar to 00-01. I took this otu before, just cant remember how I did everything since it was over 40k miles ago.
http://forums.maxima.org/showthread....52#post5156152
Is there any REAL difference between 5th gen and 5.5th gen?
Old Aug 22, 2007 | 04:24 PM
meccanoble's Avatar
Sports Button FTW
you are the man! Thanks for the info MaxBoost925, thats the exact same one I used last time.
Old Aug 22, 2007 | 04:26 PM
Drug Money
Yeah, 00-01 has a fuel return line, 5.5 doesn't.
Old Aug 22, 2007 | 04:31 PM
Drug Money
Man coilpacks are expensive - I spent like $420 on them.
Old Aug 22, 2007 | 07:31 PM
meccanoble's Avatar
Sports Button FTW
I hope that fixes your issue atleast
Old Aug 22, 2007 | 07:40 PM
steven88's Avatar
Need A Light?
try getting the walbro 190lph....
steven88's Avatar
Need A Light?
I think he already bought coilpacks....I'm going by the info said by the OP
Old Aug 22, 2007 | 11:40 PM
Drug Money
Yeah. Aye, what model 190lph do I use?
Old Aug 23, 2007 | 11:36 AM
Drug Money
You know, it could be something very stupid. Since the fuel collector is at the front of the gas tank, my car is on a slope and it's on low.... Perhaps It's not sucking in gas.
