Cat Converter ?
Old Aug 22, 2007 | 06:13 PM
Laker1's Avatar
Cat Converter ?
Where is the cheapest place to buy a cat converter for a 2000 Maxima.My car came back with a P0420 code and i need to pass emissions.It is a cali spec with 93,000 miles.
Old Aug 22, 2007 | 07:11 PM
Stardust's Avatar
F---ing Kangaroos
www.google.com
Old Aug 22, 2007 | 08:33 PM
CoolMax's Avatar
is invisible
http://forums.maxima.org/showthread.php?t=29750
Old Aug 22, 2007 | 08:57 PM
oldngivout's Avatar
Willing to learn
You do realize that the P0420 code refers to the Bank 1 catalyst, which is integral with the y-pipe. Not a cheap fix any way you go about it.
Old Aug 22, 2007 | 09:09 PM
Laker1's Avatar
What do you recommend.
Old Aug 23, 2007 | 05:29 AM
oldngivout's Avatar
Willing to learn
Well there are several ways to go about it. You could start by monitoring the front & rear O2 sensors on Bank 1 at the same time to see if they are indeed indicating a bad converter. Some people have removed the front converters and the y-pipe altogether and replaced with an aftermarket pipe. O2 simulators are then required to fool the ECU. I don't really know enough about this procedure to comment further. Realistically though, when this P0420 code is generated, replacement of the y-pipe is the simplest solution, though not the cheapest.
Old Aug 23, 2007 | 05:30 AM
rmh3093's Avatar
Only gentoo powered Maxima!
P0420 mean one of the precats in your y-pipe is going bad... you need a new y-pipe and/or an o2 simulator.... not a cat
Old Aug 23, 2007 | 05:51 PM
Laker1's Avatar
If i was to put a catttman y pipe on would it pass emissions.Also should i replace the sensors.
Old Aug 23, 2007 | 05:59 PM
NmexMAX's Avatar
dot dot dot ...
IMO, if the cats are bad, you might have other problems.
Think, root cause.
Old Aug 23, 2007 | 06:32 PM
irish44j's Avatar
retired moderator
P0420 is referring to a bad reading on the front precat by the secondary 02.
There are two, and only two ways to remedy this based on past experience with this (both personal and reading on here).
1. replace the front precat. no.
2. install a $10 02 simulator to tell the computer that everything is fine. I just did this a couple weeks ago and passed emissions last week. I strongly suggest this route. Just make sure you hide the 02 sim and the wiring in case they do a visual inspection.
DO NOT buy a new catalytic converter. P0420 has nothing to do with the main cat whatsoever.
Old Aug 23, 2007 | 06:33 PM
irish44j's Avatar
retired moderator
no, because on a cali spec car a ypipe does not replace the front precat, only the rear. P0420 is a front precat code.
Old Aug 24, 2007 | 06:27 AM
mist max2000's Avatar
i thought on cali spec the 0430 was the rear bank (closest to radiator, headers/exhaust manifold if you will) and the 0420 was the front bank, (y pipe),...are you sure irish?> and if you are my next ? to you is then whats a 0430? y pipe...
Old Aug 24, 2007 | 07:21 AM
oldngivout's Avatar
Willing to learn
P0430 is the radiator side, Bank 2, the bolt to the manifold pre-cat.
P0420 is the firewall side, Bank 1, the y-pipe pre-cat.
Old Aug 24, 2007 | 07:43 AM
rmh3093's Avatar
It will pass inspection no problem, you will still need an o2sim though.
Old Sep 15, 2007 | 07:11 PM
LucKie1nE's Avatar
EBAY..
Old Sep 15, 2007 | 07:19 PM
TurtleHead
Originally Posted by LucKie1nE
EBAY..
:attention:
We can't pull pictures off your desktop either.
maxinout93
Oct 31, 2015 02:04 AM
09maxshawn11
Sep 30, 2015 10:28 AM
sliptap
Sep 30, 2015 05:57 AM
