Is oil on spark plug normal? (large pic in thread, to show detail)
Old Aug 25, 2007 | 06:11 PM
soundmike's Avatar
Very sound, Mike
I finally managed to do this. Everything went well until i got to the right-most plug on the rear bank (the one closest to the MAF).
The plug came out with some oil on it. The tip didn't have it though (although the picture below shows it has, that's only because it eventually dripped down to it).
Is this normal? I may have introduced oil into the new plug though. After putting everything back together i now have an engine light on.
Old Aug 25, 2007 | 06:18 PM
TurtleHead
No, it's not good. Usually means worn cylinder walls, bad piston rings, bad PCV or excessive vlave stem guide clearance.
Old Aug 25, 2007 | 06:27 PM
soundmike's Avatar
Very sound, Mike
Those don't sound good. I guess my next step would be to bring this to the dealer? I never got an engine light prior to changing the plugs, so i don't even know what to tell them.
Can i at least drive the car around for a while? Everything seems fine right now (other than the light), in fact it's idling very smoothly.
Old Aug 25, 2007 | 06:47 PM
nismopc's Avatar
Before you get all concerned and worried, check your "plastic" valve cover. It's probably cracked and that is the most common location for the crack. Check it out before thinking the worst from above posted thread.
Old Aug 25, 2007 | 06:48 PM
TurtleHead
Did you hook everything up right? Did you forget to connect a hose? Did the engine run well before changing them?
Old Aug 25, 2007 | 06:55 PM
slickrick's Avatar
+1 just replaced mine thanks to E55's help...there was def. some oil under that rear valve cover when we took it out.
Old Aug 25, 2007 | 07:07 PM
soundmike's Avatar
Very sound, Mike
Yep, i hooked everything back up. I only took 4 hoses off and labeled them. In fact, i "dotted" everything i touched with blue tape so i know what to put back.
What is this "plastic" valve cover you guys are referring to? Do any of you have a picture of this by any chance?
Thanks!
Old Aug 25, 2007 | 07:08 PM
boondoxmax's Avatar
common problem with 02-03. Dont get to concerned. Gaskets need replacing that's all.....
GO RED SOXS.............................................. ......
Old Aug 25, 2007 | 07:19 PM
soundmike's Avatar
Very sound, Mike
Honestly, this is a relief. So i am actually hoping that's what's causing it.
Now to figure out why i have an SES light.
Thanks, everyone!
Old Aug 26, 2007 | 07:30 AM
djfrestyl's Avatar
Suspension Yoda
Out of curiosity, which gaskets?
Old Aug 26, 2007 | 08:23 AM
slickrick's Avatar
I think he means the rear valve cover gasket...
Old Aug 28, 2007 | 12:54 PM
NYBronxCT's Avatar
Just had the same problem wiith my tune up. It is not the valve cover gasket, it is the "down shoot" gasket of that plug of the valve cover which, I was told by Dave B, cannot be replaced. You need a whole new valve cover for $130. Have had no problem since.
Old Aug 28, 2007 | 01:02 PM
DasYears
multiple cylinder misfire as a result of oily azzed plugs. just throwing out a possibility
Old Aug 28, 2007 | 01:05 PM
soundmike's Avatar
Very sound, Mike
Thanks, i actually figured it out thanks to NmexMAX. It was because i put the car on ACC (inserted key) while the MAF/TB was disconnected. The code i pulled was P0233. I just did an ECU reset and the car is good as gold again
Old Sep 15, 2007 | 10:35 AM
2002 Maxima SE's Avatar
Is it ok to let the oil drain down into the cylinder when replacing this plug or do I need to get all the oil out before removing the plug?
Old Sep 15, 2007 | 04:11 PM
UKmaxima's Avatar
I just had this same concern last weekend. The board went down so I didnt have help from anyone. I figured out that oil was leaking from the valve cover down into the metal tube that the plug is in. Mine had been there so long that the oil was red and smelt burnt making me think the engine had been filled with ATF.
All is well with my car 1000 miles after the plug change, except I discovered I need a new rear precat as bits of mine were in the main cat. Found that out as I was fitting a test pipe
Old Sep 15, 2007 | 04:18 PM
SoonerFan's Avatar
Cletus
i know i have bad rings and mine looked like this
Old Sep 15, 2007 | 05:40 PM
STILLENGLE's Avatar
yea IIRC like sooner is saying he had the same problem replace your valve cover and gaskets.
Old Sep 15, 2007 | 06:31 PM
I replaced the valve cover and gasket. While I was in there, I also put a bead around the entire manifold.
I looked all over the old valve cover where the ring meets the spark plug hole, but I could find no crack. I'm not sure how oil was getting in there.
Old Sep 15, 2007 | 06:41 PM
UKmaxima's Avatar
The valve cover gasket has nothing to do with this problem. The valve cover itself and the oil baffle plate under it have a clearance too large around the tube that the spark plug slides down. Oil leaks through this gap and down into the tube and fills it up. If you have no oil stains or carboned up threads in an area of the thread length, you do not have a ring problem, otherwise all threads on the plug would be dark as the oil on the exterior of the plug would have come from within the combustion chamber.
Old Sep 15, 2007 | 06:48 PM
I know that, I replaced the gasket because I replaced the valve cover. Putting RTV around was more about preventative maintenance, rather than keeping oil out of the spark plug hole.
My post stated that I checked the ring around the spark plug hole and could find no crack in it (many people do). I'm not sure how oil got into that spark plug hole but none of the others.
Old Sep 16, 2007 | 09:14 AM
MyBlue02's Avatar
from dave b....04-06 (6th gen) rear valve cover- $38.39
i don't know what your smoking thinking its $130+
you need the 04-06 as it is a better cover
Old Sep 16, 2007 | 01:42 PM
Whatever you do...don't do this ^^^^^^^^^^^^^^
I was wrong, following the advice of another thread. Further, you'll want to use the grey (import) RTV, not blue. You only need a little, just a dab in the corners where the head has a 90 degree bend. I wound up doing the job twice and I'm glad I did. The RTV all the way around came right off, it wasn't going to seal at all.
Lesson learned.
Old Sep 17, 2007 | 06:22 AM
Epacy's Avatar
Unsuccesful STL Coordinator
It's fine, it will just burn off.
Old Sep 30, 2007 | 09:46 AM
phillyse's Avatar
ditto post above..its gaskets
Old Feb 20, 2008 | 11:31 PM
MADMAX2003's Avatar
Lifesavers
Just wanted to say thanks to all you guys for the informative stuff. You really saved me time and money from the..stealer****s...yeah..anyway..God bless..GO MAX.ORG
Old Feb 21, 2008 | 08:07 AM
wyche89's Avatar
does anybody have a howto with pictures on how to replace the rear valve cover with an 04-06 valve cover?
Old Feb 21, 2008 | 08:09 AM
ghostrider17's Avatar
Good thread. Good pics.
So, help me out here: you have to remove the intake manifold to get at the rear cyl. bank and spark plugs, correct?
Did any of you guys with the "bad valve cover" notice any unusual amounts of oil mysteriously disappearing from your oil res. b4 you replaced the cover??
i'm wondering if an ounce of prevention might be worth my effort on this one....
gr
Old Feb 21, 2008 | 08:14 AM
KRRZ350's Avatar
The FSM, follow it anally. Also, 3m auto scuff pads are helpful, and be very careful when removing the old permetex grey from the corners that it doesn't fall into the head, it is perfect size to block the oil return passage on the rear head
Old Feb 21, 2008 | 08:16 AM
KRRZ350's Avatar
gr
Correct on removing manifold, however you can pull plug #5 with it still on and check for oil, it seems 3 & 5 are usually the ones that get wet anyways.
The amount of oil lost is miniscule compared to what gets past the cylinder walls or pushed out the pcv on the 3.5
Old Feb 21, 2008 | 08:32 AM
Kewl. Thanks.
I'm probably better-off installing the PCV catch-can, and keeping all that muck out of my manifold and catalyst.
Stupid Crappy Nissan Piston Rings!!!!
gr
Slamrod
Sep 3, 2015 07:38 PM
Maxboy23
Aug 21, 2015 11:02 AM
Turbobink
Aug 15, 2015 07:20 AM
1992maximase30
Aug 5, 2015 09:27 PM
maxima297
Aug 3, 2015 12:50 PM
