SES light after Spark plug change on VQ35
Old Aug 26, 2007 | 11:31 AM
Will's Avatar
I just replaced the spark plugs, but not long after, the Check Engine Light came on. The idle was also high (1000 rpm in Park). The only thing "wrong" I may have done is that when the air intake plenum was off, I used a bit of throttle body cleaner to wipe off the gunk inside.
Any ideas as to why the light would come on, and the idle high? I've got the FAQ for the SES reset, but thought I'd post anyways to see if this has happened to others who did plugs or not.
Thanks.
Old Aug 26, 2007 | 11:49 AM
slickrick's Avatar
reset your ecu and see it if comes back on...
Old Aug 26, 2007 | 12:01 PM
pbn85's Avatar
never clean the inside of the tb...this happened to many people before on here when they cleaned their tb's. Im sure thats what set the ses off
Old Aug 26, 2007 | 12:14 PM
Will's Avatar
Ack! So SilverMax, did people end up having to replace anything? I was thinking that too, but I didn't drench the TB, and thought a shallow clean was better than nothing. I just pushed the butterfly back, squirted a bit, and wiped, making sure not to use too much solution.
Anyways, I followed the reset procedure, and the light went off. Idle is still high at 1000 rpm though.
Is disconnecting the negative terminal necessary at this point?
Old Aug 26, 2007 | 12:19 PM
pbn85's Avatar
http://forums.maxima.org/showthread.php?t=521347
Old Aug 26, 2007 | 06:56 PM
03BlkSETE's Avatar
Oooh! bad move.
Old Aug 26, 2007 | 11:48 PM
SoonerFan's Avatar
Cletus
after i did that, i had to replace the TB and ECU
Old Aug 27, 2007 | 09:27 AM
NmexMAX's Avatar
dot dot dot ...
Mine seems to be fine after I let it sit with the negative cable disconnected for a few days.
Old Aug 27, 2007 | 12:39 PM
MyBlue02's Avatar
did you move the butterfly valve???
Old Aug 27, 2007 | 05:38 PM
NmexMAX's Avatar
dot dot dot ...
Sure did. Treated it like my 4th gen.
Old Aug 29, 2007 | 06:17 AM
Will's Avatar
Quick update, kind sirs. My buddy helped me with an idle re-learn on his OBD2 + laptop combo, but it wouldn't respond. So then I disconnected the negative terminal overnight, and even though the SES does not come on anymore, the idle is still high (850 rpm under load at NOT). What I did this morning was disconnect negative terminal again, but this time, I stepped on the brake pedal, held it for 30 seconds, and pumped it a few more times so I can use up any residual power left to completely drain the ECU's capacitors of any memory.
If the above doesn't work, throttle replacement time. Nissan dealer sells a re-manufactured one now that's cheaper, and apparently more beefed up. Will a new throttle chamber require a re-learn?
Maxboy23
Aug 21, 2015 11:02 AM
Turbobink
Aug 15, 2015 07:20 AM
rhonster
Aug 6, 2015 05:46 PM
yat70458
Aug 3, 2015 01:16 PM
maxima297
Aug 3, 2015 12:50 PM
