Programming the fob/keyless entry
Old Aug 30, 2007 | 03:27 PM
2KBluePearlMax's Avatar
So I bought a new battery for the fob as the old one was dying. Is there an easy way for reprogramming the fob with the new battery without taking it to the dealer? I read a thread that said "Get in & lock the doors
2.Insert the key into the ignition 6 times within 15 seconds
3.Hazard lights should flash
4.Put key back into the ignition & turn to Accessory
5.Press the master door lock (on drivers door arm rest) unlock/lock
6.Hit the lock button on the remote
7.Hazards should flash
8.Pull key out and open the drivers door and then close it
9.It should be set " I tried this several times and got absolutely nowhere. Any suggestions would be appreciated. I just want my keyless entry back!
Old Aug 30, 2007 | 03:30 PM
maximadave's Avatar
detailerdaveb@gmail.com
You don't have to reprogram the fob when you replace the battery.
Old Aug 30, 2007 | 09:14 PM
Drockb418's Avatar
i have an question to this tread could we use one of the after market controls or it needs to be the factory?
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
flu2000
Sep 14, 2015 12:34 PM
videomano
Sep 8, 2015 03:28 PM
