MAF housing direction
Old Aug 31, 2007 | 02:03 PM
rmh3093's Avatar
Only gentoo powered Maxima!
The stock MAF housing has an arrow showing which way air is supposed to flow though the MAF housing. I was trying to make a shorter HAI so I turned my MAF housing around. Now my car wont stay started. Does the MAF have to be installed in a certain direction to work or do I have a IACV tube issue.... everything was working before I started playing around
Old Aug 31, 2007 | 02:42 PM
Stardust's Avatar
F---ing Kangaroos
Yes it has to be installed in the correct direction
Old Aug 31, 2007 | 02:54 PM
NmexMAX's Avatar
dot dot dot ...
Look at the MAF sensor housing closely, there's an arrow. Once you locate the arrow, right above that arrow, it reads 'FLOW'.
Seems like the answer to your question is in the question you asked.
Old Aug 31, 2007 | 03:19 PM
SoonerFan's Avatar
Cletus
if it didnt matter...would there be a freaking airflow direction arrow
Old Aug 31, 2007 | 03:33 PM
DasYears
this thread makes me laugh.
Old Aug 31, 2007 | 03:38 PM
rmh3093's Avatar
yes I can read.... it's just that the MAF doesnt "look" like it needs a certain direction, i didnt know if that arrow was to ensure that the MAF screen was on a certain side or if it was because of the MAF itself... flipping things around did fix the issue but I cant tell why it would make a difference.
Old Aug 31, 2007 | 03:40 PM
Stardust's Avatar
F---ing Kangaroos
SoonerFan's Avatar
Cletus
it makes a difference...doesnt matter why
Old Aug 31, 2007 | 03:46 PM
rmh3093's Avatar
maybe not to you, but some people like to understand why things are the way they are
Old Aug 31, 2007 | 03:48 PM
NmexMAX's Avatar
dot dot dot ...
Take a look at the actual sensor and see what you learn.
Old Aug 31, 2007 | 04:11 PM
SoonerFan's Avatar
Cletus
take the sensor out of the housing
DasYears
i didnt even look, but im guessing that the element has plastic which would keep airflow off if, say, your engine backfired and shot a bunch of gas or carbon or WE back up there. if its backwards, that would keep the INCOMING air off the element...
Old Aug 31, 2007 | 04:18 PM
MerlotMax's Avatar
"Does the MAF have to be installed in a certain direction to work"
If you want to know, just use google "MAF-How it works" -this is what you will find:
http://www.autoshop101.com/forms/h34.pdf
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
