First ever - Modified Axle Bracket
Old Sep 7, 2007 | 01:32 AM
MaxBoost925's Avatar
Drug Money
Well as many of you know - my car has been really low in its lifetime and the times that I dumped the car (24 inches or less off the ground to the fender) The passenger side axle bracket always snapped in half causing my passenger axle to slide slightly out of the transmission and leak all the fluid out but then it slides out just enough so that the car cannot drive anymore - meaning it won't move.
I had to tow it home twice because I snapped it on 2 occasions.
I had my fabricator who makes RB powered 240sx's modify my existing axle bracket (this will be my 3rd one).
Here's the original:
And here's the modified one:
Old Sep 7, 2007 | 01:33 AM
Drug Money
Here's one more picture:
2 Gussets were welded under each side and the middle was filled with cut steel. It snaps usually around where the hole in the middle is.
Apparently these brackets have high sulfur content making it very weak - it's casted so you can't expect much.
Old Sep 7, 2007 | 08:32 AM
rmh3093's Avatar
Only gentoo powered Maxima!
looks nice, hope it holds out well for you
Old Sep 7, 2007 | 08:59 AM
Kyle00's Avatar
WSH for teh cup
But this is your first modified bracket, correct? I hope this one works better than the last 3 for you
Old Sep 7, 2007 | 11:41 AM
Drug Money
First one for me and all of the .org, no one has tried this before.
Old Sep 7, 2007 | 11:44 AM
Kyle00's Avatar
WSH for teh cup
I see. The best of luck to you with it
Old Sep 7, 2007 | 03:41 PM
maxima985spd
i go low and stay low my axle bracket never broke. I wish we could make it so the axles itself doesnt get fawked up
Old Sep 7, 2007 | 03:47 PM
RA030726's Avatar
I'm nutty for Nissans
What was the cost? I never new these were breakable till a local friend needed one, just this past month.
An sr20froum member had one made from scratch, for weight. Its aluminum. I wonder which would be stronger.
http://www.floridasr20s.com/gallery/...8/DSC06052.jpg
Old Sep 7, 2007 | 04:12 PM
00SEMAX19's Avatar
Wow! nice mod man...I never knew you could brake that though
Old Sep 7, 2007 | 04:19 PM
DasYears
the max must be an uber boat @ 24"...suspension geometry FTL
Old Sep 7, 2007 | 04:32 PM
Drug Money
That looks sick. If this doesn't work - I'm having my mech make one out of scratch as well.
Old Sep 7, 2007 | 06:16 PM
BEJAY1's Avatar
Conecarver
Geez, and I thought 24.75" was slammed.
Old Sep 8, 2007 | 12:21 AM
Drug Money
haha, that's pretty low.
Old Sep 8, 2007 | 04:54 AM
L.M.L.
I never understood why ppl run their cars that low...
Old Sep 8, 2007 | 01:09 PM
BLACKonBLACK98's Avatar
Former Vendor
i think the machined one should be stronger. i was always taught that welding cast metal was a no no. is this problem 5th gen specific or is it a issue with 4th gens too? hope it works out.
Old Sep 8, 2007 | 11:38 PM
Drug Money
Because it's gangster.
Old Sep 8, 2007 | 11:39 PM
Drug Money
Never heard of it on a 4th gen. I'm the only guy it happens to in 5th gens.
Old Sep 8, 2007 | 11:58 PM
made in china's Avatar
Huh, I had a broken one also. They do seem brittle.
Old Sep 9, 2007 | 11:00 AM
Drug Money
haha I retract the statement.
-Never heard of it in 4th gens.
-Happens to very FEW 5th gens.
haha, yeah there's high sulfur content in them.
Old Sep 9, 2007 | 02:34 PM
Maxim(a)SerjVQ's Avatar
Nightmare = Reality
ah, I was wondering if this was a fabbed up part to align the rear axle. good luck with the mod. Why aren't you fabbing up a custom bracket instead of modifying the stock? cost?
Old Sep 9, 2007 | 03:51 PM
Drug Money
Time. I had to get something before HIN 9/29.
Old Apr 16, 2013 | 12:36 AM
fatboyslim86440's Avatar
Luckily my black GLE is a garage ornament... I'm sitting at 23.75 on factory rims and factory tires.. Axles are bad tho... :/
Old Apr 16, 2013 | 05:20 AM
Quickywd01's Avatar
You're a noob.
TallTom
57
Oct 14, 2025 05:16 PM
Apr 16, 2020 05:15 AM
Calabar
Oct 5, 2015 09:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
-ReLLiK-
Sep 8, 2015 12:02 PM
