TL rims on Maxima!
Old Sep 7, 2007 | 02:01 AM
02'maxed-out's Avatar
TL rims on Maxima!
would a set of 06 TL 17" stock rims fit on an 02 maxima???
also, could you run 245/40/17 tires on stock 02 rims ???
anyone with advice and input would be appreciated...
MaxBoost925's Avatar
Drug Money
Please refer to the wheel and tire forum.
Old Sep 7, 2007 | 04:28 AM
Rydicule's Avatar
Don't you know who I am?
I don't know much about Hondas, but one of my buddies does a lot of work on his Accord (which is to TL as Maxima is to I), and his wheels only have four lugs... not sure if this has changed as he has an older one.
Old Sep 7, 2007 | 06:25 AM
MintVQ35's Avatar
From my understanding most of the newer honda/acura wheels that are 5 lug have the same bolt pattern as our maximas, 5 x 114.3.
Old Sep 7, 2007 | 08:17 AM
SoonerFan's Avatar
Cletus
buy a TL...wheels look good on it
they wont fit a maxima
Old Sep 7, 2007 | 08:26 AM
Majestic Ken's Avatar
thank youu, i thought seeing 240 front ends on civics was enough, but switching wheels would be noticable being you drive a maxima
Old Sep 7, 2007 | 09:14 AM
zero2sixtyZ's Avatar
You embarrass me.
TL wheels and other Honda/Acuras for that matter usually have a much higher offset. My friends TL Type-S wheels are somewhere in the +50-55mm offset range. So I'm gonna go with no.
Old Sep 8, 2007 | 08:07 AM
joebangaa's Avatar
Old Sep 8, 2007 | 11:40 AM
00SEMAX19's Avatar
Yes, the wheel if they would fit without rubbing on the caliper would sit inside the fenderwell so much that you will want 20mm spacers to make it look right.
Old Sep 8, 2007 | 12:27 PM
You embarrass me.
True, didn't think about spacers.
Old Sep 8, 2007 | 01:04 PM
CoolMax's Avatar
is invisible
Old Sep 8, 2007 | 02:41 PM
KLOOGY's Avatar
L33t BMW Drivah
I've heard Bentley wheels look awesome on Maximas.
Old Oct 2, 2007 | 09:00 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by vq35
damnnnnn
You see what happens
Old Oct 2, 2007 | 03:21 PM
Subzero's Avatar
Just because you put on acura wheels don't mean your going to get acura reliability/resale value
Old Oct 2, 2007 | 04:17 PM
Drug Money
I can post that though cuz im OG right?
Old Oct 2, 2007 | 05:46 PM
DasYears
no for 2 reasons:
1: youre not OG enough
2: stretched tires automatically remove you from the OG shield
Old Oct 2, 2007 | 06:52 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by DasYears
no for 2 reasons:
Seems like a valid point.
Old Oct 2, 2007 | 08:16 PM
irish44j's Avatar
retired moderator
OP, the offset on the 04-05 TL 17" OEM wheel is 45mm I believe - so most likely the 06 offset is similar. I would check on the acura forums for additional information, but even 45 offset is in to far, IMO.
btw, next person to flame in this thread is going to get a ban. try me.
Old Oct 2, 2007 | 08:22 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Don't cross-breed brands.
Old Oct 2, 2007 | 08:24 PM
NmexMAX's Avatar
dot dot dot ...
FTBastardizing.
irish44j's Avatar
retired moderator
Old Oct 2, 2007 | 08:26 PM
irish44j's Avatar
retired moderator
FTBastardizing.
edit. nevermind...
Old Oct 2, 2007 | 10:40 PM
Drug Money
no for 2 reasons:
hahahahahahaha.
Old Oct 2, 2007 | 10:58 PM
MorpheusZero's Avatar
flame.
Old Oct 2, 2007 | 11:25 PM
The Law's Avatar
I R The Law
LOL! Its hard to ban somebody when tim does it too
Old Oct 3, 2007 | 01:50 AM
DasYears
i have +45's, the front is OK (marginally needs a spacer) but the back def needs spacers to look right.
Old Oct 3, 2007 | 01:55 AM
Drug Money
+45 is really bad.
You need a +20 in the front and +10 in the back to fit flush.
The Law's Avatar
I R The Law
If your on stock height, then +45 is alright but if your lowered, +45 will look so ugly without spacers.
Old Oct 3, 2007 | 01:56 AM
The Law's Avatar
I R The Law
+45 is really bad.
What you talking about!? I need a +30 and I'm flush.
Old Oct 3, 2007 | 01:59 AM
Drug Money
My style is different
Stretched tires ftw!
Old Oct 3, 2007 | 06:31 AM
NmexMAX's Avatar
dot dot dot ...
+45 is really bad.
You referring to spacers? Are you sure those aren't reversed?
I have +45 and 15mm spacers in the rear, 5mm in front. 8" wide though.
Old Oct 3, 2007 | 04:27 PM
DasYears
well im dropped about an inch, and the front is ok (you could use a 5mm at most) and the back could use 15-20mm to be flush. but i have 2.5" lip wheels so they stick out a little more than flat face wheels. however, 20mm in the front would look...uke:
Old Oct 3, 2007 | 05:48 PM
irish44j's Avatar
retired moderator
no, it's not. see?
Originally Posted by MorpheusZero
flame.
really?
hahahahahahaha.
really?
What, did you think that just because I like you guys you can ignore me? think again.
tothemax2003
Wheels/Tires
Sep 1, 2015 06:01 AM
YourLocalAsian
Aug 17, 2015 02:33 PM
criminalslang810
Aug 16, 2015 08:12 AM
RealityCheck
Aug 5, 2015 06:18 AM
