Loose Foglight
Old Jul 26, 2001 | 12:21 PM
jazzy8's Avatar
I have been reading through the How To's , etc. but can't seem to find the answer to this. Yesterday I discovered my driver's side foglight was 'rattling' around in the bumper. What keeps the assembly tight in the hole? Is it a screw that can be tightened, or a spring clip thingie? Any suggestions would be a help.
Thanks in advance.
Old Jul 26, 2001 | 01:56 PM
DooBall's Avatar
just push them in from the outside
Old Jul 26, 2001 | 04:29 PM
[maxi-overdose]'s Avatar
there is a clip that holds the fog, located behind the bumper. I would open my splash guard and go under the car to take a look.
good luck
Old Jul 26, 2001 | 05:05 PM
young1976's Avatar
the 5th gen fogs are held on by two friction tab like thingys on top and one bolt on the bottom, try pushing it in to see if it pops back in, if not, look around underneath the splash shield or should I say... no no.
(Go to the dealer and have them fix it under warrenty?)
Old Jul 26, 2001 | 10:57 PM
Dario's Avatar
You might check underneath could of swore there was a screw that held in the foglight as well as the white push pop thingy
Old Jul 27, 2001 | 05:05 AM
young1976's Avatar
There is a bolt on the bottom side of the light and it strips out easy, mine is almost stripped.
Heat0212
Oct 24, 2020 12:36 AM
D Mason
Jun 21, 2016 04:43 AM
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
