JWT Turbo Maxima article
Old Oct 21, 2000 | 07:27 PM
brianw's Avatar
(also posted in the general forum)
Scans... 2.11MB for all 7.
http://fyzxcrew.dragonfire.net/maxima/jwt01.jpg
http://fyzxcrew.dragonfire.net/maxima/jwt02.jpg
http://fyzxcrew.dragonfire.net/maxima/jwt03.jpg
http://fyzxcrew.dragonfire.net/maxima/jwt04.jpg
http://fyzxcrew.dragonfire.net/maxima/jwt05.jpg
http://fyzxcrew.dragonfire.net/maxima/jwt06.jpg
http://fyzxcrew.dragonfire.net/maxima/jwt07.jpg
From Sport Compact Car Magazine, December 2000 issue.
Won't be up forever though, limited space. If anyone with more space wants to host 'em, let me know so I can point people to it!
And the `99 Maxima mentioned on the first page is none other Jay Lee!
Old Oct 21, 2000 | 09:46 PM
nismomax's Avatar
They've already got the Dec. issue out?
Where did you get the issue?
Old Oct 22, 2000 | 08:04 AM
madmax2k's Avatar
Thanks for the scans! Cool info!
I am quite surprised at how the kit is tuned though. Its all low end and zero top end. With the way the stock powerband is (max power at redline) they could have easily gotten 350 + at the wheels. Why they didnt is beyond me. The way the JWT kit is tuned, a stock Maxima wont be far behind it on the highway from a high rpm roll! After 5000 rpm, the power drops way too fast...it looks like JWT is dropping boost off drastically. There must be a reason for it though...they are not idiots.
But, with the peak power outputs Stillen has gotten from the Vortech at only 6 psi, I still have to wonder why JWT didnt get more top end out of this car.
Old Oct 22, 2000 | 07:32 PM
mingo's Avatar
the turbo charger dissapoints me. but what i still dont' get is, no shocks??
Old Oct 22, 2000 | 08:10 PM
Neo Max's Avatar
Has anyone actually seen a dyno graph of a supercharged 2k? I'm curious as to the validity of stillens claims and even if true they have no low/mid range power compared to the turbo. Likewise, I'd like to see this car dyno'd with a good clutch as slippage might have caused the poor numbers.
Old Oct 22, 2000 | 08:24 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Diederik has a sc on his auto and he puts down 250 fwhp. Add about 30 more for the 5 spd.
BTW, thanks for posting the article Brian.
Old Oct 22, 2000 | 09:52 PM
Neo Max's Avatar
I am by no means disputing your claims but are you telling me that a 5spd is putting 280hp to the ground with 6psi? That sounds more like stillen bragging again. I do think the JWT kit should make better #'s than the sc especially if it can hit up to 10psi. If the loss is not from a weak clutch then something else seems fishy with the system. Again, I'm not trying to be insulting but just playing the devils advocate.
Old Oct 22, 2000 | 10:13 PM
Y2KevSE's Avatar
It's cool. If an auto can put 250 to the ground, then the 5 spd should be somewhere around there (this is derived from 176 fwhp for autos and 191 fwhp for 5 spds). They've stated numbers around there, but you know Stillen...
I also believe they should've goten higher numbers with 10 psi. There must be a reason for the low numbers (weak clutch is one of them).
Old Oct 23, 2000 | 12:16 AM
mingo's Avatar
this is real odd. i remember at the LA auto show, i read that lil plaquard thing about the eibach maxima and it said 350ponies.. i even have a pic of the car, but i dind't get a close up shot of the literature that accompanied it. or maybe i was thinkin' of another turbo car there.. that show was realy awesome.. gotta see the slr..
Old Oct 23, 2000 | 04:42 AM
madmax2k's Avatar
I recieved a dyno plot from Stillen which showed:
Max Torque 231 ft lb @ 5800 rpm
Max Power 281 hp @ 6400 rpm
All numbers at the wheels.
But, the plot is suspicious. See my post:
https://maxima.org/forums/showthread...0&pagenumber=2
Finkle
Sep 27, 2015 09:53 PM
xUNIxPanther
Aug 27, 2015 10:09 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
minus
Fluids and Lubricants
Aug 18, 2015 07:29 PM
