Jerky transition from 1st to 2nd..anyone else?
Old Jul 31, 2001 | 07:19 PM
Maxmann's Avatar
I cannot consistently get a smooth shift when transitioning from 1st to second gear. I usually shift around 3500-4000 RPM and I usually end up kind of lurching just a bit. Kind of like it thunks into gear. Even at lower RPM's I tend to do this. I doubt it is the car, I think it is just me. Is this typical? I don't let completely off the clutch real quick...just ease off and it seems to minimize the effect.
thoughts? I don't generally experience this in transitioning to any other gear.
srm
Old Aug 1, 2001 | 06:26 PM
AdamK's Avatar
Could this per chance be the fuel cut issue in the 00/01 5 speed maximas?
Old Aug 2, 2001 | 10:59 AM
Maxmann's Avatar
Well, I would probably agree that that might be it, but my car was "supposedly" fixed for that, although I can tell very little, if any, difference. I drove my 93 Max today and get a similar reaction...I think this is just me.
srm
Old Aug 2, 2001 | 11:19 AM
jnovember's Avatar
You experience seems very familiar to mine. Just had the ECM redone because Check Engine Light came on.
As I stated in http://forums.maxima.org/showthread....ine#post416933
"Used to feel the fuel cutoff (on/off sensation) in stop-and-go traffic and when cruising in any gear at-or-below 2,000 rpm (even doing 50mph on a highway in 5th gear). Also felt I had to be VERY deliberate when shifting to make the shifts smooth. (Never had to do that on any of the 6 other 5 spd cars I've previously owned.)
The car is now a TOTAL joy to drive."
Old Aug 2, 2001 | 01:31 PM
maximadave's Avatar
detailerdaveb@gmail.com
When you take your Maxima into the dealership give them a copy of the TSB on the tranny. Have them replace BOTH TCM'S. They replaced mine and whoa, what a difference. Most dealerships will only replace only 1 that is affected on the TSB
Maximadave
Old Aug 5, 2001 | 10:18 PM
azylstra's Avatar
BOTH TCMs? I've never heard of having two TCMs. The only one I know of is the one in the TSB, original 31036-3Y100, then 3Y101, then 3Y160. What is the part # of the hidden second TCM? You're not referring to the solenoids, are you? Please explain, thanks!
James92SE
142
Jan 2, 2024 09:23 AM
user 11122324
42
Jul 18, 2022 03:35 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
