Rear Brakes Moaning
Old Aug 9, 2001 | 10:31 AM
To-the-Max-ima's Avatar
For some reason, my rear brake moans with I brake softly (like tapping the brakes or lightly riding the brakes). This happens usually at low speeds. I was stuck in traffic last weekend (low speeds, light braking) and it was so annoying. Also, it got a lot worse with the RSB on so I took it off. Does anyone else have this problem. Please let me know. Thanks.
Old Oct 2, 2009 | 10:19 AM
Chad Valk's Avatar
I am having this same problem right now. About a month and a half ago it started. I had it into the dealership last week and they said everything looked fine and lubed up everything. On the way home (and since then) the sound is no more prevalent and happens more in busier traffic. It is like a moaning/rubbing sound (like the tire is rubbing against the car or something...very odd sound) but it is more dominant in parking lots, low speeds and turning into parking spots. Half-way on the brake pedal seems to be the trigger point. Anyone have any thoughts!? TIA!!
Old Oct 2, 2009 | 10:43 AM
fflint_18's Avatar
Make sure the pins that the calipers ride on are lubed and not bent. the calipers should move smoothly on them.
At low speed you will get this type of noise if they are binding.
Old Oct 10, 2009 | 02:34 PM
stephen90's Avatar
I have the same problem but it was solved after I switched out therotors due to a frozen caliper that was dragging on my rotors for nearly 4 months causing it to warp.
Old Oct 10, 2009 | 03:16 PM
Col Ronson's Avatar
i usually get brake noise when the weather is colder. i thought this was completely normal.
Old Oct 10, 2009 | 11:44 PM
a33i30's Avatar
moans
mvm062
Nov 30, 2020 09:00 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
homeyclaus
Sep 3, 2015 06:15 PM
A32goldylocks
Sep 2, 2015 06:39 AM
