Problems after Y-pipe install
Old Aug 13, 2001 | 10:10 PM
Sly's Avatar
Sly
Has anybody noticed any of the following after installing a Y-pipe?
-reduced fuel efficiency (not due to more spirited driving)
-more frequent engine knocking under load (running too lean?)
-more engine vibration at idle.
I know when I installed mine I didn't do a perfect job, one of the gaskets probably isn't seated properly causing a small leak, but would that be the cause of my problems? If I spend the $75 to have a shop profesionally reinstall it, will my above mentioned problems go away? If it makes a difference, I have the CA/NLEV emissions.
I'm also worried about how long a Stillen Y-pipe will last in Michigan and am contemplating just replacing it with a Cattman SS Y-pipe. I bought the Stillen Y used to begin with. Hopefully Cattman's fitment will be better since the Stillen Y needed some major "adjustments" to fit.
Old Aug 13, 2001 | 10:32 PM
PhatGuy
Did you reset your ECU?
Old Aug 13, 2001 | 10:35 PM
maximadave's Avatar
detailerdaveb@gmail.com
No problems with my Stillen y-pipe. I actually got slightly better fuel economy. It might be the gaskets have it checked out at that shop when you have in reintalled
Maximadave
Old Aug 13, 2001 | 10:40 PM
Sly's Avatar
Sly
I haven't reset it yet. Just before I installed the Y-pipe I had my ECU reprogrammed at the dealer to fix a warranty issue (basically just an idle adjustment to fix a idle drop/stalling problem). Will resetting the ECU erase the new program?
Old Aug 14, 2001 | 04:37 AM
UMD_MaxSE's Avatar
Got Bent?
Reset it by just unplugging the battery for a few hours or overnight... it won't affect any reprogramming done previously
Lakersallday24
Nov 7, 2024 07:31 PM
JRod28
Dec 29, 2023 09:56 PM
stromm
Aug 27, 2015 04:13 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
