Adding extra LED's to alarm
Old Aug 14, 2001 | 09:07 AM
Dustyroads's Avatar
I know Kev has done this and I think there are a few other that have as well. Talk to me here, were did you splice the wires for your LED's and what voltage LED's did you get?? Kev, did you drill into the dask to mount the LED's or are they in the A-pillar?? I can't tell by the pictures you have posted. Thanks for the info guys!!
Old Aug 14, 2001 | 09:13 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
I used the clock wires for power. The LED's have 3 wires, 1) +, 2) -, and 3) security. Make sure you get 12V or else you might start blowing electrical stuff. I did no drilling, so it's just wedged against the A-pillar.
Old Aug 14, 2001 | 09:18 AM
Dustyroads's Avatar
So did you pull out the clock and get to the wire behind it, or did you go elsewhere for the connections?? How did you run the wires for them, through the dash?? Hey, thanks for replying so fast!!
Old Aug 14, 2001 | 09:27 AM
Y2KevSE's Avatar
You're welcome.
Yup, I pulled out the clock, spliced the wires, and ran it down under the dash. Not through the dash... under the dash (can be seen if you peep under the steering column).
Old Aug 14, 2001 | 09:34 AM
Y2KevSE's Avatar
Before anyone complains/comments/ridicules... yes, this is rice.
Old Aug 14, 2001 | 10:16 AM
SkyMax Jr.'s Avatar
Re: .
yeah...but it just looks so damn good
Old Aug 14, 2001 | 11:11 AM
Dustyroads's Avatar
Re: .
That's okaym it's acceptable rice, or at least I think it is acceptable. Might I ask what kind of LED's were they? Did you have to get some kind of special 3 lead LED's or something, since they take +,- and alarm?
Old Aug 14, 2001 | 12:23 PM
JKiMaxAC's Avatar
they way i set up my leds...
i did that same a Kev.. with the power.. but i drilled 3 holes in mine.. one on each side of the clock, and one on the top... it look's pretty good.. lights up the cabin at night.. and will blind's u if u sit the drivers seat. ^^ but i just got the buld from radio shak.. they were 5volt blue leds.. i don't know the numbers for it.. but i can find them there.. and if your gonna drill ne thing.. get snap-in leb panel mounts # 276-079... happy lighting.....
Old Aug 14, 2001 | 12:53 PM
Dustyroads's Avatar
Nice..thanks for the LED mounts...I will look for the LED's.
Old Aug 14, 2001 | 12:59 PM
Y2KevSE's Avatar
Re: Re: .
Jane and I got some while we were on vacation in Hong Kong. You can take a look at them in the lighting section of my homepage (there's also a short video clip if you're interested).
Old Aug 14, 2001 | 01:44 PM
Dustyroads's Avatar
You damn importers!! That's cool, so basically I'm screwed!! You didn't happen to buy a whole shipment of those suckers and bring them back with you?? Well, I'll give the regular old LED's a try and we'll see what happens. Thanks again Kev and JKiMaxAC!!
Old Aug 14, 2001 | 04:39 PM
RussMaxManiac
Okay, this still does not make sense. I need someone to help me out here.
Most LEDs have 2 pins, they are a diode basically.
Now I have never seen a 3 pin led, but obviously they have them.
Now explain this to me exactly how you hook it up to the clock? Do you tap into the clock or the led next to the clock? While your driving at night or anytime are the LED's still flashing? I don't want this to be irritating... Thanks
Old Aug 14, 2001 | 04:56 PM
Jane97SE's Avatar
Used force to obtain Admin powers
Greg, :X
Old Aug 14, 2001 | 05:47 PM
RussMaxManiac
Just got back from RADIO Shack, and I looked at all there LED's. All there ONE color LEDs where 2 pins, all there mixed colored ones are 3 pins. Now tell me this. They had blue in the 2 pins, but they do not carry blue or mixed color with blue in it in a 3 pin configuration.
I need someone that can tell me HOW we can hook up these led's if they are 2 pins without making the other led's dim? Ideas?
Old Aug 14, 2001 | 06:04 PM
Dustyroads's Avatar
Originally posted by Jane97SE
Greg, :X
Well...I have a :X right back at you there Jane!! Good to hear from you!!
Old Aug 14, 2001 | 06:08 PM
Dustyroads's Avatar
Russ....I'm very sure you will only need the regular 5V 2 pin LED's. I'm sure the little LED net to the clock has two wires running to it. A ground and an alarm or power, whatever. It will moret han likely be a 5V wire so you can just splice into those 2 wires and add the LED's. I hope this helps. I'm going to work on this as well, so I'll let you know when I get some more information.
Old Aug 14, 2001 | 06:34 PM
RussMaxManiac
That won't work. Like I said before, it will cause the LED to become dim. I have done this in the past. It puts more load on the same voltage and cuts down on it. Must be another way.
Old Aug 14, 2001 | 09:30 PM
JKiMaxAC's Avatar
Russ.. then even it out.
if u have a volt meter, find out the output of the wire.. and cut it in half.. if its a 5volt.. get 2, 2.5v leds.. i put 3, 5volt leds in with one 2.3ohm fuse that they have for leds.. i don't know wut it really dose.. but the guy at the radio sak told me that it even's out the power output... i dunno how.. but it works..
Old Aug 14, 2001 | 09:59 PM
MaineI30's Avatar
nitro
I have two of those Nitro-blue ultra bright LEDs but haven't installed them yet.
I haven't decided where to put them, basically. Any thoughts? Front doors? front a-pillars?
I can tie them into an accessory wire so they flash when the ignition is turned off.. they have a built-in relay and third wire
Old Aug 14, 2001 | 10:06 PM
Y2KevSE's Avatar
Re: nitro
Front a-pillars or front doors would work really well. I like putting them on the a-pillar because they light up the whole thing.
Old Aug 14, 2001 | 10:49 PM
Dustyroads's Avatar
Alright then Russ, then just get a lower voltage LED....I don't quite understand how adding 2 LED's would make the current drop that significantly this is of course presuming that you wired the LED's in parallel, if you for some reason wired them in series, they will be much dimmer. There should be plenty of supply current in the 5V line to supply multiple LED's, but since you have had problems with it in the past, I would say get these LED's and you should be set. They are lower voltage and they should do you just fine. Here's the Radio Shack part numbers: 900-8005, they are kind of expensive though. I hope this helps!!
Old Aug 15, 2001 | 05:36 AM
RussMaxManiac
Okay got the # thanks. Also what about those plastic inserts that you use to stick th e led into, then into the hole that you drilled? Radio shack didn't have those at all. Ideas? Also, the wiring. Basically you mean taping into each tire and go into the new led. I forget though, which side of the new LED do I need to go into, the one with the flat part, or the other? It's been a long time since I was in electronics! lol
Old Aug 15, 2001 | 06:13 AM
Dustyroads's Avatar
Well, if you got a 5mm LED you can get a 5mm LED holder. Check out http://www.radioshack.com/ and search for this part number 276-079. This is a 5mm LED holder, they have other size holder as well, so you can get a different size LED and the appropriate holder. Let us and especially me know how it goes, I will be doing this soon as well, perhaps even this evening, but I'm not sure...I'll let you know if I run into any problems. Oh if you look at the LED, usually the longer lead is the (+) lead, also you can look through the diode and look for the lead that has a dark marking on it. That indicates the positive side. Also, if you power the LED up and it doesn't work then switch it around, but I'm pretty sure I remember that correctly. I'll check on the polarity and get back to you.
Old Aug 15, 2001 | 08:41 AM
MaineI30's Avatar
Re: Re: nitro
Where specifically on the a-pillar would you put them? Against the windshield side? Would you cut a hole? Where would you cut the hole? What is the meaning of life?
Old Aug 15, 2001 | 09:18 AM
Y2KevSE's Avatar
Re: Re: Re: nitro
I wedged them between the dash and the pillar so they're somewhat parallel to the pillars. No cutting or drilling was necessary.
You will know the meaning of life once you know how to live.
Old Aug 15, 2001 | 09:02 PM
RussMaxManiac
I ordered 4 LED's today from Radio Shack. Man those damn things are expensive. I ordered 2 extra in case I screw up. But if not I can use them somewhere else . Anyways, they will be here in 3-5 days suposely!
Let me know what you got so far in your install.
Old Aug 15, 2001 | 10:23 PM
ohboiya's Avatar
I don't understand or can't picture what we're trying 2 do here ... Kev ... I looked @ your page ... but all I see is a black pic with some blue lites ... have a daytime pic? Are we actually putting in new lites or just changing from red to blue?
Old Aug 15, 2001 | 10:52 PM
Y2KevSE's Avatar
The are in addition to the red LED on the clock. There's not really much to see in the daytime.
You know the little gap between the a-pillar and the dash? Imagine a blue LED wedged between... pointing upwards.
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
lrb6805
Sep 24, 2015 05:03 PM
