Why cant I win?
Old Aug 16, 2001 | 02:49 PM
MAX2000JP's Avatar
My friend(Briguymax) has a 97 Maxima 5 speed with a Cattman Y, JWT Popcharger, Apexi Catback, and ACT Street Clutch as performance mods. I have similar mods and he still beats me. We raced from 40 mph in second gear to about 95 mph. Second gear we are pretty even, but when he hits third he pulls about a car on me. I have similar mods, so I dont know why he beats me. Did they change the gearing in the 5 speed version of the 5th gens? I am thinking seriously about buying a UDP will this help me out in third gear(midrange)?? Is there something wrong with my car?? I thought that the 5th gens were quicker up top.
Old Aug 16, 2001 | 02:56 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Try switching cars and see the outcome is.
Old Aug 16, 2001 | 02:59 PM
MAX2000JP's Avatar
Kev it isnt driver error....we are both good drivers and didn't miss any shifts. Thats what puzzles me!!
Old Aug 16, 2001 | 03:01 PM
Y2KevSE's Avatar
Hmmmmmmm........ You should come out on top, even if it is just by a little.
Old Aug 16, 2001 | 03:10 PM
AznWontonboy's Avatar
what rpm do you shift at, andd what does he shift at? no granny shifttin right?
Old Aug 16, 2001 | 03:14 PM
MAX2000JP's Avatar
I shift at redline...I shift by letting off the gas and then dumping the clutch out to engage. I dont know where he shifts at??
Old Aug 16, 2001 | 04:22 PM
UMD_MaxSE's Avatar
Got Bent?
I still say switch cars and see what happens.... its the only way to rule out differences between drivers... Also, are you heavier than him?
Old Aug 16, 2001 | 04:37 PM
ToYLeT902's Avatar
JET Speed Lab
i granny shift
cept for last night i was shifting at 6k
Old Aug 16, 2001 | 04:44 PM
ToYLeT902's Avatar
JET Speed Lab
i granny shift
Old Aug 16, 2001 | 04:59 PM
MAX2000JP's Avatar
[QUOTE]Originally posted by UMD_MaxSE
I still say switch cars and see what happens.... its the only way to rule out differences between drivers... Also, are you heavier than him? [/QUOTE
We are similar in weight....Maybe a 5-10 pound difference or so
Old Aug 16, 2001 | 05:20 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
[QUOTE]Originally posted by MAX2000JP
You BOTH should get dyno runs at the same place and same time frame for comparisons. I'd like to know why.
What are the weights of the 4th gen vs. 5th gen?
Old Aug 16, 2001 | 05:27 PM
SkylineGTR's Avatar
the clutch maybe?
Y2KevSE's Avatar
4th gens are definitely lighter than 5th gens. What model Max does Briguymax have (GXE's are lighter than SE's)?
Old Aug 16, 2001 | 05:39 PM
UMD_MaxSE's Avatar
Got Bent?
also, what kind of rims does he have? the stock 2k SE 17's are HEAVY.
Old Aug 16, 2001 | 05:41 PM
MAX2000JP's Avatar
Brian has a SE and so do I. My car is equipped with 17" rims vs 16" on his 97'.... that could make a very slight difference.
Old Aug 16, 2001 | 05:57 PM
Y2KevSE's Avatar
Wow..... you guys should definitely try swapping cars for a few races.
Old Aug 17, 2001 | 12:04 AM
BriGuyMax's Avatar
Our shifts are right on together....neither of us has a driver advantage. my car pulls in gears NOT during shifts. He has the best chance on a 2nd gear start. he's with me almost all the way though second....I pull only VERY slowly. Then as soon as we hit third, it's all over for him. If we start from a dead stop it's an even worse story for his 5th gen. I will stick by my guns and say that mod for mod....the 4th gen is RIGHT with the 5th gen. if he gets his custom b-pipe, he'll probably be just about even with me (from a roll), then I'll spray
We probably weigh about the same, and I have a disadvantage of heavy stereo equipment in the back of my max.
If we had the money, we'd go get dynoed.
Old Aug 17, 2001 | 12:10 AM
EZ's Avatar
EZ
Sorry to break it to you pal but your car is a good 200 to 300 lbs heavier than his. Look up the curb weights of the standard SE and you will see this. Plus with your 17s and his 16s, that is even more weight.
Old Aug 17, 2001 | 07:01 AM
Sonic's Avatar
Uh, crazy idea, and probably wrontg, but here it goes. 1.)The peak HP figures for the 5th gens are at redline, right? The 5th gen pulling that high accomplishes two things, one he doesn't end up losing power up there like a 4th gen would and second, his power dropoff into 3th gear isn't as severe. 2.)His engine is newer, and is probably still 'stronger;, meaning tighter seals, higher compression, and as a result, 'more power'. Ok, shoot away.
Old Aug 17, 2001 | 07:57 AM
mingo's Avatar
then I'll spray
i didn't knwo that spraying windshield washer fluid makes your car go faster... i'ma try that at the track next time.
Old Aug 17, 2001 | 09:04 AM
BriGuyMax's Avatar
did I say windshield washer fluid.....I don't think so....
Old Aug 17, 2001 | 12:42 PM
DMan_2KMax's Avatar
Excuse my Ignorance but . . .
what the heck does "granny shifttin"? Thanks guys.
xUNIxPanther
Aug 27, 2015 10:09 PM
speednsound007
Feb 27, 2001 06:34 PM
MrBurner
Dec 6, 2000 12:34 PM
2ndMAX
31
Nov 21, 2000 11:19 PM
MaineI30
Oct 15, 2000 07:48 PM
