how to disconnect battery?
Old Aug 18, 2001 | 07:48 PM
DooBall's Avatar
i thought it was pretty simple... but i'm not 100% sure what im doing.
i dont want to kill myself doing this newbie checkup
search didnt work, i'll delete this after someone helps
Old Aug 18, 2001 | 07:52 PM
Greg's2kGLE's Avatar
Loosen the negaitve side. The right side. It's the one that isn't covered. Just loosen the nut a little and pull it up.
Old Aug 18, 2001 | 07:58 PM
ispeed's Avatar
Tools Required:
1 10mm Socket
1 Socket Adapter
1 Ratchet
1 6 Pack of Beer (your choice on manufacturer)
Battery Removal Instructions:
Put the rachet/socket assembly together.
Put socket on the 10mm nut on the negative post.
Turn several times (remember left loosie, righty tighty).
Pull straight up and negative cable will come off terminal.
If you want to remove the entire battery, repeat above instructions for the positive terminal.
One word of advice ... be careful not to turn ratchet so far as to touch the positive terminal and the negative terminal together. You could be burned or worst case scenerio, blow the battery up. Also don't smoke over the battery as the Hydrogen fumes that might be escaping from the battery are extremly flamible.
There you have it. Now that the work is done, finish the 6 pack and enjoy the feeling of doing a job well done!
Old Aug 18, 2001 | 08:49 PM
TarHeelMax's Avatar
This should be a sticky.
Old Aug 18, 2001 | 08:52 PM
How about a "How-To"? Kev......I know you're out there
Old Aug 18, 2001 | 09:13 PM
DooBall's Avatar
before:
after:
Old Aug 18, 2001 | 09:20 PM
melanthius's Avatar
battery
Don't worry too much about the battery, just make sure you don't touch both terminals at the same time with both your hands (you will get electricity arching over your heart and could cause a heart attack)
but just touching the negative terminal can't hurt you.
Old Aug 18, 2001 | 09:34 PM
got rice?'s Avatar
if you're ****, wear safety googles in case of an explosion. Sulfur and crap in your eyes isn't a pleasant experience.
Old Aug 19, 2001 | 12:39 AM
Menasor's Avatar
after:
Don't worry, just don't let the positive and negative terminals touch each other. I almost f***** myself up
Old Aug 19, 2001 | 01:31 AM
serin's Avatar
before:
after:
nice
Old Aug 19, 2001 | 02:11 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
If you guys want to add this to the stickies, go right ahead. I wouldn't know who to give credit to.
Next sticky... How to fill up gas.
Old Aug 19, 2001 | 02:19 AM
KaxMaxSEAE's Avatar
Sulfur? Try sulfuric acid...
A friend of mine was checking his oil, and some static electricty FROM HIS NYLON JACKET caused his battery to explode. He was lucky, no battery parts rearraged his face.
Nasty, nasty, nasty. Don't be afraid of it, but do use some caution.
Old Aug 19, 2001 | 10:16 AM
serin's Avatar
i didn't know it was that dangerous. i've just been doing it with a mind to not touch the + lead. i always thought it would just arc if it did.
in any case, just don't remove the + cover.
Old Aug 19, 2001 | 10:26 AM
MaineI30's Avatar
Re: battery
How is this possible?
Old Aug 19, 2001 | 10:27 AM
MaineI30's Avatar
always stand with one foot in a pail of water and one foot on the ground while working with the battery. this will help in case you contact the hot side
Old Aug 19, 2001 | 10:53 AM
ispeed's Avatar
Re: battery
Just touching the two terminals won't hurt you unless your wet. If you are sweating or doing something in the rain however be careful because it will give you a little jolt.
I remember when I was working on a truck one time. It was so damn hot I was sweating like never before. My shorts were completely soaked in sweat. I was leaning up against the bumper of the car (the ground point for anyone who needs a chart) and then I touched the positive battery terminal not paying attention and not knowing it would have any effect. Its not a painful shock but more like licking a 9v battery. (come on we've all done it ... licked a 9v to see if it was still good)
But just be carefull, with sparks and don't touch the two terminals. If anyone has read their owner's manual or any owner's manual for that matter, they talk about "jumping" a battery. You are supposed to put the positves together on both batteries. Negative on the good battery and negative on a ground point on the car for the bad battery car. They do this because sparks can fly after the terminals are connected. These sparks can ignite the Hydrogen that is released and then *boom*
Old Aug 19, 2001 | 11:53 AM
DooBall's Avatar
grr, i cant losen the nut!
its real small, and the nut is in a tight spot.
my wrench/rachet/pliars/fingers/everything doesnt have enough room to turn it.
GRR, and i'm worried im gonna strip it.
anyone have any tips?
Old Aug 19, 2001 | 11:58 AM
UMD_MaxSE's Avatar
Got Bent?
mmmm 9V battery shock
Old Aug 19, 2001 | 01:18 PM
Y2KevSE's Avatar
Hehehe I used to do that too!
gigabyte
Jan 6, 2017 06:05 PM
doctorpullit
Mar 29, 2016 11:08 AM
bigfrank
Oct 1, 2015 12:51 PM
maxima297
Sep 30, 2015 03:32 PM
