intake trouble
Old Aug 21, 2001 | 07:45 PM
zgrm100's Avatar
I went to the local station to put on my JWT pop charger, and the guy had no clue how to do it. he didnt know where the sensor or some **** would go? Any ideas?
Old Aug 21, 2001 | 08:08 PM
theMax's Avatar
hey where you at?
There has to be someone here from the org in your area that can help you install it! I would really give it a try, its not very hard. Check the links 0n this board
here is help from punkdork as noted in the sticky
As far as the stock scoop goes, I left it on both cars but that is a matter of preference. It does seem that it would push some cool air toward the intake. You can remove it if you desire.
Take the hole airbox out including the maf tube (there is a section where you can disconnect it from the scoop) and you remve the MAF tube after losening a hose clamp.
Take out the four bolts holding the maf to the airbox.
Set aside your airbox.
I find it easiest to remove the cone from the velocity stack at this point.
Bolt 3 of the new bolts that came with your pop charger to the maf tube leaving the one that will be closest to the top of the strut tower empty.
Slide the maf back into the area you removed it from. Slide makes it sound easy.. it actually requires a lot of work and a couple good strong shoves.
Tighten the hose clamp on the MAF.
Grab the mounting bracket, put one end over the empty hole on your pop charger and the other end to the airbox mounting point on your strut tower and bolt them both on.
Screw the cone filter back onto the velocity stack.
Crank that baby up and hear it suck in the air.
Here are some pics from a link provided by YJ (pics appear to be taken by gr8bone based on the URL :
http://members.nbci.com/gr8bone/intake
Old Aug 21, 2001 | 08:20 PM
RBa's Avatar
RBa
That shop has some idiots working there.
If I were you, I wouldn't consider going back there for any future work. Man I really feel sorry for all of their customers..
If you were in the NYC area, I would help you. This has to be the easiest mod next to installing the FSTB... If you don't mind gettin your hands dirty, give it a try yourself.
Old Aug 21, 2001 | 08:21 PM
DooBall's Avatar
Re: hey where you at?
taking your car to local station to install an intake is like taking your computer to SEARS....
they wouldnt know wtf to do with it...
Old Aug 21, 2001 | 08:31 PM
RBa's Avatar
RBa
Re: Re: hey where you at?
Funny.. About 5 years ago, When I didn't know jack about cars, I bought my first Stillen intake for my 95 Max and took it to Minekeet. The guy actually knew what he was doing but charged me an arm for it.
I guess it depends where you live.
Old Aug 21, 2001 | 08:58 PM
zgrm100's Avatar
Re: Re: Re: hey where you at?
i live in long island. any1 know a good shop around here?
Old Aug 21, 2001 | 10:56 PM
DooBall's Avatar
Re: Re: Re: Re: hey where you at?
ultima performance on sunrise highway
www.ultimaperformance.com
Old Aug 23, 2001 | 10:39 AM
zgrm100's Avatar
Re: Re: Re: Re: Re: hey where you at?
do they do a good job on maximas? What about price wise. any experiences with them? thanks for ur help
aw11power
Oct 10, 2021 04:57 AM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
zmcneely13
Sep 26, 2015 02:26 PM
