Rear Sway-Bars
Addco RSB Group Deal
There are many people that like the Addco bar here on maxima.org. I put together a group deal for $118.64 shipped. This is a one time thing. If interested, check the complete details in the group deal forum. BTW, the Addco bar is 7/8".
Re: Addco RSB Group Deal
Thanks For the info guys, is there anyone here that knows how thick the Stillen bar is.
7/8" seems very small for a 4k lb car, I would be expecting 1.2"-1.8" for the weight, but then again I usually have dealt with rear-wheel drive cars in the past. Any advice on that^?
Re: Re: Addco RSB Group Deal
As other points of reference, the Malibu in my sig (about 3450# net) has the 22mm (about 7/8") rear bar as part of the F41 sport suspension package. And the heavier OE F-body rear bars are between 21mm and 24mm.
Norm
The reason why the rear bar is not that thick is because RWD cars have 60%(est) of the weight in front. Therefore a super thick RSB is not needed. I think most aftermarket makers don't want to make the car oversteer much(if at all) so they don't go overboard on the stiffness.
What sway-bar is better for the 5th gen, the Addco or Stillen. The Stillen looks better but I can't find any specs on the bars to judge the actual performance of them.
Also... it hard to compare the performance of these sway bars from the diameter alone. Most bars attach to both the suspension and the chassis to translate chassis roll to the opposite wheel. These bars do not attach to the chassis at all. Since the Addco bar attaches to the beam and the Stillen doesn't, I wonder how that attachment affects anti-sway performance, assuming diameter is the same.
And, finally, it not exactly correct to say the Maxima's rear suspension has no anti-sway bar... it does, it is built in to the way the multi-link torsion beam design works (see http://www.se-r.net/about/g20/scc/oct98/tb.html for a good article on the G20 beam, like the Maxima's). The Stillen and Addco units supplement the performance of the existing anti-sway bar.
And from all accounts, very well indeed!
bbsitum
Sep 11, 2015 04:55 PM
that was long...
