foglight question... simple
Originally posted by serin
if i put in the PIAA h3 platinum super whites in my stock foglamp housing, will i need to upgrade my wiring to not fry it? if so, is there a procedure out there???
u don't need to really change all the wiring just to upgrade to PIAAs...but just take into consideration that H3s are one of the easiest bulbs to blow..
if you want to upgrade the harnesses, i think you can buy these harnesses from local autopart stores. they have clips so you can just plug them in..
that's fine...
that's fine...
it should be ok..read the labels on the box carefully..sometimes the bulbs will draw only stock current and produce brightness of higher wattage..
It amazes me that every so often I have heard the rumors that PIAA's blow quickly. I have multiple sets on my Maxima for a year and not one has blown. All different sizes to boot.......it is like most manufactured parts, you could get a defective one but their customer service is 1st rate! I did not like a color....so I called and they forwarded a new one via Fedex at their dime! Lets see Raybud? or others promote their products in a similar fashion. Go with PIAA and if your looking for a discount try www.autobulbdepot.com or www.autosupermart.com.
Heat0212
Oct 24, 2020 12:36 AM
ricky7780
Nov 3, 2015 03:22 PM
Hdnseek
Sep 9, 2015 05:55 AM
