Y-pipe problem
Old Oct 4, 2001 | 06:47 AM
omax's Avatar
Y-pipe problem
My car sounds like a motorcycle at low RPMs.It didn't sound like this before I was thinking maybe it was lose but it yesterday it didn't now it does again.Any body know what this could be.I have had it about year and a half.
Old Oct 4, 2001 | 06:51 AM
UMD_MaxSE's Avatar
Got Bent?
check the flex joint and make sure it is not leaky. What pipe do you have? Stillen or Cattman? Also, make sure the gaskets are secure at the cat joint and at the manifolds....
Old Oct 4, 2001 | 07:02 AM
Jeff K's Avatar
It's more then likely the gasket between the cat and the Y-pipe. You need to get a new metal one from Nissan because all other gaskets fall apart.
Old Oct 4, 2001 | 07:22 AM
got rice?'s Avatar
Look at his signature
2K Blk 5spd se Stillen intake,Eibach pro kit ,Cattman ss y-pipe
Old Oct 4, 2001 | 07:42 AM
UMD_MaxSE's Avatar
Got Bent?
doh... i be stupid
Old Oct 4, 2001 | 02:51 PM
MAX2000JP's Avatar
You might have a hole in the flex section.
Old Oct 4, 2001 | 03:00 PM
AznWontonboy's Avatar
doh... i be stupid
you need wonton supplements.
Old Oct 4, 2001 | 04:07 PM
UMD_MaxSE's Avatar
Got Bent?
got any?
Old Oct 5, 2001 | 05:25 AM
omax's Avatar
If the flex joint is back is their a way to replace it.Well I guess I'll have to put it on the ramps to see what the problem it.Thanks for the help
Old Oct 5, 2001 | 05:37 AM
PIONEER's Avatar
don't need ramps. just start the car, have someone press the gas while you look under to see where the air/smoke is blowing out of.
Old Oct 5, 2001 | 03:45 PM
omax's Avatar
Hey Pioneer I hope you don't mind but I used your Sig as wallpaper on my computer.Don't worry when people ask I give you your props.
lrb6805
Sep 30, 2015 08:12 AM
lrb6805
Sep 17, 2015 04:49 PM
Violator
Sep 9, 2015 10:14 AM
