Head lights Adjustment
Old Oct 4, 2001 | 07:13 PM
titot4u's Avatar
I just placed new Xenon HID's on my 2001 Max. They look great except I dont like where they are brightening up the road. They seem to low and I cant seem to see incoming pot holes when driving. Makes it kinda difficult not having those hi-beams. Is there any adjustments to bring these lights up alittle bit higher?
Thanks in advance...
Titot
Old Oct 4, 2001 | 08:48 PM
JKiMaxAC's Avatar
wut HID's did u go with?? and how much did it run??
Old Oct 4, 2001 | 10:57 PM
BigDogJonx's Avatar
Re: Head lights Adjustment
Titot
There is a small metal screw on the back, just turn it either way with a socket wrench. That will either lower or raise the assembly.
Dixit
Old Oct 5, 2001 | 04:40 AM
titot4u's Avatar
HID'S
Mine are H4's made by Phillip.
Old Oct 5, 2001 | 05:54 AM
naidd's Avatar
Titot
Interesting. After switching to HID, I have the feeling I should point my headlights further DOWN because of the brightness difference.
Did you have any problems before you switched? Did you have to use high beams often?
As to the question, it was already answered There's a screw on the back of each headlight.
Old Oct 5, 2001 | 06:30 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Clockwise aims down...
Counter-clockwise aims up...
8mm wrench
Old Oct 5, 2001 | 01:02 PM
BigDogJonx's Avatar
8mm wrench
Aint no need to get TECHNICAL on the forums here..........
Its alright, its only KEV
Old Oct 5, 2001 | 01:16 PM
Y2KevSE's Avatar
You guys left that out, so the poor guy might be twisting his life away.
Old Oct 7, 2001 | 09:55 AM
JKiMaxAC's Avatar
For all the ppl that got the HID'S to get your haed lamp out do u need to take the bumper off??? Or is there another way?? And how long will it take to get them out??
sorry if i'm reposting something that some one said b4.. but the search this dosen't work that well..
Old Oct 7, 2001 | 10:08 AM
ispeed's Avatar
Re: ???
If you are getting an aftermarket set of HID's, there is no need to remove the headlamp assembly at all. All you have to do is take out the old bulb and put in a new one.
If you are talking about the 2K2 headlamp assemblies, no you still don't need to take the bumber off.
Old Oct 7, 2001 | 10:13 AM
JKiMaxAC's Avatar
Re: Re: ???
Hum.. i didn't know that.. some one said b4 that u need to take the bumper off to get the headlamps out.. i guess not.. so i can just un screw all screws holding the headlamp in w/o removing the bumper.. sounds good..
Old Oct 8, 2001 | 04:19 AM
titot4u's Avatar
I Did The Adjustment....
Thanks guys. I did the adjustment and everything is bright as hell.
mvm062
Nov 30, 2020 09:00 AM
iflexsteel
Sep 15, 2015 03:37 AM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
doobadoo
Aug 15, 2015 06:43 PM
