LED project continues tomarrow evening..
Old Oct 4, 2001 | 07:44 PM
RussMaxManiac
I might have figured it out with the help of one other max owner here. I also had to use some ohms law as well to figure out what resistor I need exactly for my leds. So I will let everyone know how it comes out. I will try to work on the car tomarrow evening if I get some time.
This is on adding more additional led's to the stock alarm...
Blue colored.
Old Oct 4, 2001 | 08:09 PM
RussMaxManiac
Re: LED project continues tomarrow evening..
Also, if you guys want a easier way to hook it up. I found these on the the net. http://www.directron.com/led.html They are in houston, and these have 3 wires. 12v, ground, and alarm signal. Basically you hook it up to all the wires on your clock that you need and this will power up fine!
Regular bright leds like I have require a resistor as well and a sorta different way to hook up to make them work. I will let you guys know.
Old Oct 4, 2001 | 08:27 PM
theMax's Avatar
12v LEDs
not sure if this will help...
Radio shack has 12V LEDs, that might eliminate your need for a resister. I used them to replace my 194s in the doors. $1 each.
Old Oct 4, 2001 | 08:33 PM
JKiMaxAC's Avatar
yea if u get a 12v led no nees for resistors.. i did the same as theMax did and i didn't need it.. but for my doam light i need them so i can have more led's work off of one line.. so i have 6 ultra white led's in my doam light.. and its bright as hell...
Old Oct 4, 2001 | 10:58 PM
BigDogJonx's Avatar
Blue colored.
Hey hope the help works out. Cause I am fairly sure with the info me and you came up with, that it HAS to work.
I am gonna get the 12V ones and do it that way. But hope yours works out.
Old Oct 5, 2001 | 05:35 AM
RussMaxManiac
My current LED's are 5v leds from radioshack that was recommened. They do not carry 12v LEDs at radioshack. They are hard to find in blue.
Old Oct 5, 2001 | 01:08 PM
theMax's Avatar
12V leds
Calling me a liar....I ordered the 12V leds online at www.radioshack.com because the store was out of stock.
Part number is below from their webpage (276-0209). I emailed their customer support with what I wanted and they returned a list of part numbers for the correct colors. Hope this helps.
12 V LED (276-0209) Specifications Faxback Doc. # 16504
Reverse Voltage:.......................................... ..............5 V
Reverse current (Vr=5V):.......................................... ....10 uA
Operating Temperature Range:..................................-40 C to 85 C
Storage Temperature Range:...................................-40 C to 100 C
Led Soldering Temperature:..............................260 C for 5 seconds
[1.6mm (1/16 inch) From Body]
(ALL-08/16/95)
Old Oct 5, 2001 | 03:44 PM
RussMaxManiac
Re: 12V leds
Sorry but that is not the LED. I SAID BLUE..... in BLUE they do not carry them. I went to radio shack and looked online. In 12v they do not.
(ALL-08/16/95)
Old Oct 24, 2001 | 05:19 PM
multiplexor's Avatar
Blue colored.
uhm so what colors did you get for the resistor?
what the ohm?
i'm trying to basically do the same
Old Oct 24, 2001 | 05:46 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Re: Re: LED project continues tomarrow evening..
what the ohm?
I think he got lazy and bought the LEDs that I have (3 wires, power, ground, and security).
Old Oct 24, 2001 | 06:55 PM
RussMaxManiac
what the ohm?
220~ ohms for 5v leds. But it depends on what amps the leds are, and now I forgot what mine were. I think .20 amp, not positive. Whatever it was it came out to near 220ohms with this formula..
Ohm = (Mains Voltage - LED Voltage) / LED Amperes, so;
Ohm = (12 Volts - 1.5 Volts) / 0.015 A
I bought the 3 wire leds as well but not used them yet.
Old Oct 25, 2001 | 03:20 AM
areX's Avatar
what i'd really like to do is use LEDs in my dash... that would be insane... but.. but... i'm scared...
Old Oct 25, 2001 | 06:17 AM
Re: Re: Re: LED project continues tomarrow evening..
oh... hehe
i figured i will need a 450 ohm resistor
just have to test that now...
Old Oct 25, 2001 | 06:26 AM
"6000 mcd 5mm Ultra Bright BLUE LED
Operates on 2.5 - 3 VDC @ 20mA.
6000 mcd typical luminosity T1-3/4 (5mm) Blue. 466nm, 29.5° viewing angle"
so from that i get:
(12-3)/0.020=450
i've been a LED freak since i was like 12... taking them out of used vcr's and ****... i'm probably gonna plug them everwhere in my max hehe
hmm quick question, if i hook up one led to the next...
ie:
assuming both leds are 3 volts, I would need 6 volts to power them
fully right? or would 3 volts cover both with enough power?
if i need 6 volts to light up both leds, then i simply need 4 leds
to accept the 12 volts?
just giggle if i'm wrong, and then proceed to correct me
hehe
thanks
Old Oct 25, 2001 | 08:10 AM
woosh's Avatar
Re: Re: Re: Re: LED project continues tomarrow evening..
so from that i get:
(12-3)/0.020=450
ie:
hehe
thanks
you would need 3volts across each LED hence a total 6 volts.
there would be 6volts remaining, so true you could use total of 4 LEDs
Old Oct 25, 2001 | 08:36 AM
haha wow my diagram didn't turn up as i wanted it to
yikes...
hmm cool good to know 4 leds would work.
so theoretically... if i use 4 leds and hook them up
to the dome light (which is 12 volts right?)
then it should work properly, without a resistor?
Old Oct 25, 2001 | 10:07 AM
RussMaxManiac
Each led will need its own resistor and its own separate connection. You can't do them all behind one resistor, it will make too much of a load.
so from that i get:
(12-3)/0.020=450
ie:
hehe
thanks
Old Oct 25, 2001 | 11:49 AM
Dustyroads's Avatar
Re: Re: Re: Re: Re: LED project continues tomarrow evening..
That would be true if he were hooking the led's up in parallel, but he isn't. He is going to hook them up in series. If he does that then he can get away with using 4 LED's and no resistor.
Essentially what he is doing, is the same thing you are doing with your pull down resistor. You have a potential that is too high and you need to match that with the level of your LED, so you put a resistor in series with the LED's to chew up some of the voltage and then you have enough for your LED but you won't blow it up. Plain and simple. No need to hook each LED up to it's own pull down resistor.
Old Oct 25, 2001 | 05:18 PM
woosh's Avatar
Re: Re: Re: Re: Re: Re: LED project continues tomarrow evening..
True, it would look like
+ 12v -|>-|>-|>-|> - gnd ( 20 ma flows ->)
3v 3v 3v 3v
Old Oct 25, 2001 | 08:55 PM
Re: Re: Re: Re: Re: Re: Re: LED project continues tomarrow evening..
3v 3v 3v 3v
yeah exactly like that
this way no resistor would be needed since the leds would be eating up the voltage properly.
sweet stuff...
maybe i'll hookup 2 bright whites and 2 blues?
seems like a fun little thing to mess around with
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
lrb6805
Sep 24, 2015 05:03 PM
