2K2 Maxima 1/4 time
Old Oct 10, 2001 | 02:01 PM
  #41
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Re: Re: Re: Re: 2K2 Maxima 1/4 time
Originally posted by Paul2kGXE
Most people are in that 2.3-2.4 range. 2.7 is quite high. You must have been either spinning your tires or coming off the line very soft.
good draggers in maximas get 2.1X and 2.2x in 5-spd's
good autos get low 2.3X. it's tough to get lower in an auto.
Old Oct 10, 2001 | 02:34 PM
  #42
Paul6speed's Avatar
Re: Re: Re: Re: Re: 2K2 Maxima 1/4 time
I can usually run a low 2.3 60 foot time. I don't expect much improvement from that. If I ran slicks, I'm sure that would help.
Old Oct 10, 2001 | 02:36 PM
  #43
SeOh2mAx's Avatar
Cant..leave..the..ORG!!
damn i stock auto with a traction problem this is nice.
i took me three days to get used to it so I wouldnt chirp the tires when I took off...but it is interesting being able to do it at will.
took me just about as long not to try and step on a clutch after having driven a 5spd for the past 4 years
Old Oct 10, 2001 | 02:40 PM
  #44
Re: Re: Re: Re: Re: Re: 2K2 Maxima 1/4 time
i don't think the slicks would even help that much on an auto unless you had a high stall TQ. it's just that power valley from 1000-3000rpms that the auto is stuck in.,
Old Oct 10, 2001 | 05:23 PM
  #45
SCCA Solo2's Avatar
Originally posted by maxracer27
My 60 ft time was 2.7. I heard this is not a good 60 ft time.
Holy crap~! Was that your first time ever drag racing? Did you launch with the E-Brake on?
Perspective:
I ran 2.4 60' footers with 15.50@93mph.
Supra meet in Vegas were having hard time with traction and were running 2.3-2.4. One managed a 1.59 though.
Next time out, work on torque braking. Right as the third amber lights up, let it rip. You should be able to cut .5xx lights if you do so.
On a bragging note:
I ran my first ever .500 RT. after a night of consistent .55x RTs.
Good times, by the way.
Old Oct 10, 2001 | 05:37 PM
  #46
AznWontonboy's Avatar
i have a question. torque braking... how BAD is it for the torque converter/tranny? Everytime i torque brake, i hear this sound that doesnt sound to nice.. at first it was the brakes, but when i push harder i found it to be another sound. i cant really describe it... anyone know what i am talking about?
Old Oct 10, 2001 | 05:48 PM
  #47
maxracer27's Avatar
Perspective:
On a bragging note:
This is the 1st and only time I ran on this car. I didn't use the e-brake, but I did have my left foot on the brake pedal and I launched at 2000 rpm. With more practice and better 60' time I should be able to get on high 14's with my stock 2k2 auto. I think I need to launch at less than 1k rpm so I can have better traction.
Old Oct 10, 2001 | 10:00 PM
  #48
if you brake torque all the time or for too long it will take some life off you tranny. what you do if you hold it for too long is boil the tranny fluid. the best way which is harder but i've been practicing and i think i have it down is called flash stalling the converter. it's when you hold the brake down all the way and just hit the gas and as soon as it hits the 2K rpm mark you let go of the brake and finish hitting the gas all in one quick motion. it's much harder to do and takes some practice but it works better and it better for the tranny.
Old Oct 10, 2001 | 10:07 PM
  #49
i've tried that but i get more wheel spin. i'll keep on practicing
Old Oct 10, 2001 | 10:15 PM
  #50
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I don't know about that.
The latest Motor Trend stats for an I35(3.5L) automatic:
0-60: 7.0 sec
1/4: 15.3/91.5mph
Old Oct 11, 2001 | 04:35 AM
  #51
lower your tire pressure to around 22-25psi. that will yield better traction. get lowering springs for less front to back weight transfer or some drag radials.
Old Oct 11, 2001 | 10:37 AM
  #52
My 4DSC
0-60: 7.0 sec
1/4: 15.3/91.5mph
Motor Trend said my car runs 15.1.
I ran 14.8 consistently.
Plus...the I35 is alot heavier than..say..a GXE.
Old Oct 11, 2001 | 11:07 AM
  #53
IceY2K1's Avatar
Re: Re: Re: Re: Re: Re: Re: 2K2 Maxima 1/4 time
Yes, but was your time SAE corrected?
I know MT corrects their measurements, so that may account for some of the difference. However, not all cars are created equal and neither are the drivers.
Still that's an AWESOME time! Can you teach me how to drive???
Old Oct 11, 2001 | 11:33 AM
  #54
theMax's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: 2K2 Maxima 1/4 time
How do you SAE correct your times? Thought that was only for HP.
Old Oct 11, 2001 | 12:10 PM
  #55
IceY2K1's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: 2K2 Maxima 1/4 time
I don't think there is a way to correct your times. I'm not sure.
If horsepower output is dependent/related to the altitude, barometric pressure, and ambient temperature then the time needs to be corrected also. Otherwise, automanufacturers would only want their cars tested during the coldest, lowest altitude, optimal tire pressure, etc..
Sounds like a good question for the car magazines, since they base MOST of their tests on 0-60 and 1/4-mile benchmarks.
Old Oct 11, 2001 | 12:14 PM
  #56
theMax's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: 2K2 Maxima 1/4 time
Maybe they mean average times not "corrected" to a standard temp/pressure/etc
Old Oct 11, 2001 | 01:03 PM
  #57
na95gle's Avatar
is it like this weird grinding sound?? kinda sounds like the brakes but not. . cause its coming from the center console?
Old Oct 11, 2001 | 02:02 PM
  #58
they can and do correct their time according to i think 60degrees a neutral baro. pressure and 50% humidity. and Adam the new GXE's don't come in standard remember. you prolly knew that but from what you said it sounded like maybe you thought they did.
Old Oct 11, 2001 | 02:06 PM
  #59
irvine78's Avatar
hmm.. decent times... i expect more out of it though. at least flat to low 15s.. did you torque brake?
ur expecting too much from the 2K2s..
255 to the crank is around 180-185 to the wheels for the automagics...pretty much what 2k and 2k1 maxima with manual tranny was pulling to the wheels...the bone stock 2K and 2K1 manual pulled about 15.3-15.4 at the track...so the number sounds reasonable to me...
Old Oct 11, 2001 | 02:45 PM
  #60
umm no, with a decent driver the 2k's were 15.1 or better at the track, they just seem to be harder to drive than a 4th gen.
Old Oct 11, 2001 | 03:05 PM
  #61
mingo's Avatar
my 60ft was 2.372 and reaction time was.. erm.. embarrasing..
Old Oct 11, 2001 | 03:40 PM
  #62
adman's Avatar
Yeah...but, the 2K2 has that COOL engine cover.
AND, IT LOOKS REALLY, REALLY, REALLY FAST!!!
ADMAN
Finkle
Sep 27, 2015 09:53 PM
laparka66
Aug 6, 2015 09:36 AM
yat70458
Aug 3, 2015 01:16 PM
