Need help removing Stock BOSE radio.
Old Oct 14, 2001 | 10:22 AM
john893's Avatar
I need some help removing the Stock radio in my girlfriends 2000 Max. It has the BOSE stereo in it. I don't even know where to begin. I do not want to leave any marks on any of the panels that I have to remove. I need access to the stereo wires so I can hook up her Val-1 Radar dector.
Thanks for any help
John
Old Oct 14, 2001 | 02:18 PM
BigDogJonx's Avatar
Re: Need help removing Stock BOSE radio.
Thanks for any help
John
Alright well you need to pull off the AC vents right above the radio. Just put you fingers in there and pull hard and the whole vent should come out. Then there is two screws to remove the radio with. Then it is out.
Dixit
Old Oct 14, 2001 | 02:28 PM
2000MaximaSE's Avatar
Re: Re: Need help removing Stock BOSE radio.
Dixit
Sure.... you couldnt even get that top vent off man...
You have to grab the vent and pull up and out. Once it pops loose you yank it strait out hard.. There are 2 screws behind it. Remove those.
Then remove the shifter surround by pulling out the coin tray. Take out that screw behind it and pop the surround up with a screwdriver.. There are 2 screws behind this so remove those too.. now the whole assembly is free so disconnect all the harness' and pull it out.. Now getting the bose free from the brackets is a BIATCH. There are 4 screws on each side and they will NOT move.. If you cant get them out you have to drill them or what i did was cut a huge deep slot in each one and used a big flat head to get em out
good luck
Adam
Old Oct 14, 2001 | 02:42 PM
BigDogJonx's Avatar
Re: Re: Re: Need help removing Stock BOSE radio.
good luck
Adam
Man just helping a brotha out.
Old Oct 15, 2001 | 01:01 PM
john893's Avatar
Thanks for the help guys. I looked at it quickly and figured I would ask you guys. I don't want to mess up her car at all. With my Lightning I am much braver.
Thanks for the help.
John
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
bumpypickle
Sep 20, 2015 08:22 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
