Weird radio problem (Bose)
Old Sep 26, 2007 | 04:25 PM
dfownz's Avatar
Hey guys,
EDIT: Both decks tried were aftermarket decks. Not the stock Bose HU. Sorry about that.
My 00 max with Bose has been acting weird all of a sudden. First the deck cut out, kinda like it was skipping. Turned it onto a radio station and it did the same thing. Thought it was a loose wire, so I started feeling around for a loose wire
Now the deck won't even turn on. So I check the fuse on it, and then solder it into the harness. Still no dice. I try another deck, STILL WON'T WORK!!!!
I checked a Haynes manual and it says nothing about a radio fuse and I couldn't find one on the panel in the car.
Also, the 2 grounds from the Bose connectors are tied into the deck ground and attached to the body.
What else can be my problem?
Thanks,
DF
Old Sep 28, 2007 | 10:28 AM
SLOW2KMAX's Avatar
Check all the wiring for the head unit besides the ground. Smething might have came loose.
Old Sep 28, 2007 | 08:15 PM
nsnrider's Avatar
make sure the antenna is connected
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
bennuss
Sep 11, 2015 05:55 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
