Cabin Air Intake
Old Oct 2, 2007 | 05:56 PM
shobuddy's Avatar
Cabin Air Intake
Over the weekend I cleaned the engine bay on my 03 SE with Gunk Engine Brite. I must have gotten some of the Engine Brite in the cabin air intake area because now when I run the air, it smells of Engine Brite. Can someone tell me where the air intake is so that I can try to clean it out. After that I'll replace the microfilter and hopefully that will do the trick.
Old Oct 2, 2007 | 06:17 PM
MintVQ35's Avatar
The cabin air filter is behind the glovebox.
Old Oct 2, 2007 | 06:56 PM
shobuddy's Avatar
Thanks, I know where the microfilter is. I'm trying to figure out where the air intake is under the hood.
Old Oct 2, 2007 | 06:59 PM
MintVQ35's Avatar
I don't understand what you're asking then, there is an air intake for the motor and a cabin air filter for the air coming into the cabin...You want to know where the air enters the cabin through the filter I guess?!
Old Oct 2, 2007 | 07:23 PM
VQ30DETT's Avatar
for the outside air that enters, it between the hood and windshield
Old Oct 2, 2007 | 09:13 PM
tonyw's Avatar
It's by the passenger wiper. You have to take some trim parts out. The GUNK smell will go away. I don't know if it's worth taking everything apart.
Old Oct 3, 2007 | 05:56 AM
shobuddy's Avatar
Thanks, if its hard to get to then I will give it a couple weeks before bothering with it. Hopefully the smell will be gone by then.
Old Oct 3, 2007 | 08:09 AM
aznaliaz's Avatar
gunk didnt do any damages to your engine? i've used it once on a customers car at the shop i worked at.. the car ran afterwards, but i dunt noe if there are long term results from it since the car was towed away.
Old Oct 3, 2007 | 08:55 AM
shobuddy's Avatar
No damage that i've noticed so far. I think engine brite is designed for engine cleaning. I used some wd40 afterwards to lube the rubber hoses. I've heard engine brite can make them brittle.
Old Oct 3, 2007 | 09:10 AM
MyBlue02's Avatar
lol...wd-40 dries out ruber as well....get some tire foam (armorall) and coat all the rubber lines with it then rines off whats left after letting it sit for a bit to soak in.
(wd-40 works by removing moisture...)
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
