nosiy belt tensioner ...
Old Oct 8, 2007 | 04:17 PM
maxspeed96CT's Avatar
The original VQ...
My tensior is real noisy , should I replace it , or would some wd-40 or grease fix it ?
Old Oct 8, 2007 | 04:21 PM
NmexMAX's Avatar
dot dot dot ...
Bearings might be shot. It's a cheap part, and easy install, so if you have the time, replace it. Until then, hit it with some type of grease. Mine never shuts up so I've stopped hitting it with grease/oil.
Old Oct 8, 2007 | 08:52 PM
erikgeis's Avatar
Don't let that WD touch the belt. As far as I know it'll eat it away. Is replacing the tensioner a difficult job?
Old Oct 8, 2007 | 11:15 PM
boris's Avatar
It's around $70 USD at stealership. You will need a good 14mm wrench; also prepare good access from the bottom of the car, i.e. remove protective shields from the wheel well. If not stucked, it should be pretty easy job.
Old Oct 9, 2007 | 06:43 AM
NmexMAX's Avatar
dot dot dot ...
@ 70USD. I got it for 40USD from Courtesy mind you. Of course, I didn't get the bracket, just the idler pulley assembly.
Unless your bracket is cracked/damaged in anyway, you should be fine with just the pulley.
Old Oct 9, 2007 | 12:24 PM
The original VQ...
is couryesy nissan were dave B is from or is that another place?
Old Oct 9, 2007 | 12:28 PM
Kyle00's Avatar
WSH for teh cup
Thats another place. Dave is from southpoint nissan
Old Oct 9, 2007 | 12:30 PM
NmexMAX's Avatar
dot dot dot ...
It's another place. But you could also get it from DAVEB. In fact, I would suggest that over Courtesy.
www.pinnaclenissan.com has a good price on it too ($44 shipped)
Old Oct 9, 2007 | 02:18 PM
ShIft_uR FacE's Avatar
what kind of sound does this make and approximately what location of the car?
Old Oct 10, 2007 | 02:42 AM
Dayton100's Avatar
I had this same sound and it basically sounds like a diesel engine. It's almost like a truck motor sound. When you step on the gas (@ low RPM around 2500) it would be non stop. There is no sound when you are driving however. You notice it strongly when you are parking or going at that speed. After replacing the Alternator Idler Pulley, the sound is completely gone!
Old Oct 10, 2007 | 11:40 AM
ReauDog's Avatar
Replace. had the same problem on another car of mine. replaced the tensioner and noise was gone.
Old Oct 10, 2007 | 12:58 PM
erikgeis's Avatar
I think replacing it would ultimately be the best.
Old Oct 10, 2007 | 03:30 PM
boris's Avatar
Unfortunately i had no time to order it by mail. And yes, this was the pulley only. (California reality)
02PearlSE
Feb 1, 2016 12:37 AM
markevans999
Oct 25, 2015 08:27 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
