Annoying squeaking coming from clutch actuator thingy
Old Oct 10, 2007 | 01:14 PM
bwinter7's Avatar
Hi guys, Whenever I am running the car in neutral with the clutch let out there is an annoying squeaking that is embarrasing. I thought it was a belt, until I got my berk intake on, and I saw that it was the clutch actuator that was shaking causing the noise. I can put my hand on it, and it stops squeaking, but I cant do anything else to make it stop. It doesn't look like there is any way to tighten the cable that runs to the bracket, and pb blaster, wd40, and white lithium grease is not working at all. Any suggestions as to what I might do?
Old Oct 15, 2007 | 07:27 PM
Matt_01SE_20th's Avatar
you need to be a bit more descriptive...im not sure which "thingy" you are talking about. are you talking about the master cylinder? slave cylinder? what year max do you have? pictures or page references from the FSM would be phenomenol here.
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
MaxLife17
Sep 8, 2015 02:36 PM
lux97Max
Sep 4, 2015 05:42 PM
trungg86
Sep 4, 2015 04:58 AM
