How toget wire through fire wall
Old Oct 15, 2007 | 06:43 PM
jr schultz's Avatar
I looked in the faq's under the car audio section, but I couldn't find an answer to my question. Where is there a factory grommet I can run some wire through from the engine bay to the driver's side of the interior? The purpose is to be able to wire in a switch for the drop resistor mod. Sorry if this is a overdone question, but I couldn't find an answer.
Old Oct 15, 2007 | 06:45 PM
Squirrel82's Avatar
Take the mudflap off and peel the wheel liner back some.Theres a hole in there.
Old Oct 15, 2007 | 07:39 PM
grey99max's Avatar
LandShark has Cosworth
1. Get a "close quarters" right-angle drill by Milwaukee - or Harbor Freight - and a DeWalt step-drill bit and drill hole(s) through the firewall under the dash.
or
2. Run wires from the engine compartment down behind the driver's fender panel and into the cable opening you see when you open the driver's door. This goes under the dash as well.
Old Oct 15, 2007 | 07:54 PM
jr schultz's Avatar
I've never had a car that doesn't have a factory grommet that goes right inside the car. Is the fender idea the best and easiest way? I'm only talking about 14 or 12 gauge wire. Thanx for the help. I plan on doing this tomarrow. I want to get my drop resistor switch done before track day on saturday.
Old Oct 15, 2007 | 08:03 PM
SilverGLE's Avatar
I'm watching you, boy...
You can also drill a hole where the clutch reservior would be through the firewall... I actually had enough room under the dash to stick a corded drill with a 3/4" bit in there.
TKHanson
Nov 24, 2018 01:39 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
