thermostat
Old Oct 14, 2007 | 05:23 PM
specvmatt's Avatar
thermostat
need a thermostat. is there a good performance thermostat out there? new to the vq community.
Old Oct 14, 2007 | 05:30 PM
Love_00_Max's Avatar
Performance thermostat is OEM.
They come quite cheap $20 for the thermostat and the metal gasket $8.
Old Oct 14, 2007 | 06:00 PM
SoonerFan's Avatar
Cletus
you dont need a performance one
how exactly will it "perform better"
Old Oct 14, 2007 | 06:02 PM
NmexMAX's Avatar
dot dot dot ...
You can mod the stock one, get a Z33 unit, or a Nismo piece.
Old Oct 14, 2007 | 06:07 PM
SoonerFan's Avatar
Cletus
Old Oct 14, 2007 | 07:02 PM
zero2sixtyZ's Avatar
You embarrass me.
+1 Z33
Old Oct 14, 2007 | 07:38 PM
AceofSpds's Avatar
wat
it opens sooner
but i would be wary of using a cooler t stat since once water gets too hot its hard to get the temp back down w/ out stopping the vehicle and or turning it off.
Old Oct 14, 2007 | 08:07 PM
jasonmax's Avatar
just get a stock one instead of getting in any trouble.
Old Oct 14, 2007 | 08:08 PM
NiSmOVQ35's Avatar
stock oem t-stat WITH Water wetter!
Old Oct 14, 2007 | 09:14 PM
wyche89's Avatar
holy crap, you have a VQ35 in a sentra and you're worried about a thermostat? lol.. forget about it.. your car has gotta fly with or without this performance thermostat
Old Oct 14, 2007 | 09:29 PM
AceofSpds's Avatar
wat
He needs a new one, its not gonna go far w/ out a thermostat.
Old Oct 15, 2007 | 06:27 AM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread.php?t=536413&page=2
Old Oct 15, 2007 | 07:57 AM
Stardust's Avatar
F---ing Kangaroos
Old Oct 15, 2007 | 09:22 AM
NmexMAX's Avatar
dot dot dot ...
So, happened to the one you have?
Old Oct 15, 2007 | 01:58 PM
ShiftVQ35
get a nismo t-stat. it opens earlier....
Old Oct 15, 2007 | 02:50 PM
specvmatt's Avatar
im not even 100% sure its the thermostat. but its a cheap fix just to see if thats the problem. the car overheats if im in traffic with the a/c on.. i live in florida.. so think of 110 degree temps with two small fans. im putting a 3rd fan on to push hot air out of the engine bay, so that should help. but im gonna replace the stock thermostat anyway. i run at about 250 degrees, which is 50 degrees too hot.
Old Oct 15, 2007 | 02:54 PM
specvmatt's Avatar
NmexMAX, thanks for the help.
Old Oct 15, 2007 | 03:48 PM
wyche89's Avatar
right.. lol.. guess that might help huh? i mis-read the post.. i thought he was just looking for a performance thermostat as an upgrade
Old Oct 15, 2007 | 06:23 PM
aksansai's Avatar
01 Maxima SE, 5-spd
Dammit, boy. You stuffed a VQ35DE in that Sentra? That must be a nasty machine.
Old Oct 15, 2007 | 07:13 PM
NmexMAX's Avatar
dot dot dot ...
The voltage curve for the sensor doesn't even go that high. It ends @ 230*F (0.01V). You would get an MIL if you were above 221*F.
How are you verifying your exact temperature?
Old Oct 15, 2007 | 08:42 PM
Jamesrc's Avatar
110 in traffic w/ A/C on. What radiator are you running? I don't think the stock 2.5 one will cut it. What you need is a "performance" radiator.
Old Oct 16, 2007 | 06:27 AM
NmexMAX's Avatar
dot dot dot ...
Units please. I'm assuming *C, but even then that's 230*F, How are you getting this data? Vehicle operating temp (warmed up) occurs @ 160*F, and from what I've observed, it hovers at around 185-196*F. 110*F would not allow the ECU to enter open loop, and the car would run very rich.
I'm hoping/quite sure the VQ35 he got came with a t-stat. And I'm also sure he's not using the QR unit.
Al > *. Cooler t-stat couldn't hurt though.
Old Oct 20, 2007 | 03:46 PM
specvmatt's Avatar
its the stock radiator from my 2.5. out of the 15 swaps that has been performed from a 2.5 to a 3.5, mine is the first with this overheating problem. all have stock radiators. when i can scrounge up some money, im going to buy a performance radiator. but its winter soon, so ill be fine. my mechanic here hooked his computer up to grab all the codes im throwing and making sure thats all good, thats what read 250 degrees, which is hot. im running very rich, which is probably the overheating issue. because of all the codes that i have thrown, the ecu is always in open loop. i want to try and work out the codes one step at a time, but was also told by the motor swap guy not to touch the wiring harness, so im taking it easy.
Old Oct 20, 2007 | 03:51 PM
specvmatt's Avatar
13.3 @106 mph.
60 ft: 2.1
weather is defintely better. thats on the same ****ty street tires that i ran a 14.6 last month with.
Old Oct 22, 2007 | 06:41 AM
NmexMAX's Avatar
dot dot dot ...
on rich AFR leading to overheating. Should be opposite if anything.
Do you have an explanation for that?
Old Oct 22, 2007 | 12:54 PM
specvmatt's Avatar
nope. im bad with cars. only overheats in hot weather and sitting in traffic with a/c on.
Old Oct 22, 2007 | 05:47 PM
P. Samson's Avatar
You are going into open loop because of the high coolant temp. Probably explains the rich AFR as well.
Old Oct 23, 2007 | 04:19 AM
specvmatt's Avatar
well then maybe once i get my overheatig issue fixed, my gas mileage will be a bit nicer?
Old Oct 23, 2007 | 06:30 AM
NmexMAX's Avatar
dot dot dot ...
Seems like a logical theory.
I would like to see how rich he is. Also, why would he go rich, in particular, in open loop?
Old Oct 23, 2007 | 11:02 AM
P. Samson's Avatar
Per the FSM with the high coolant temp. the ECM will go to open loop and it does "add fuel". With an overheated or hot engine you definitely don't want a lean mixture, especially if you are forcing it to put out lots of power. A "rich" mixture keeps the combustion temp. down. A lean mixture increases combustion temps.
Old Oct 23, 2007 | 11:35 AM
NmexMAX's Avatar
dot dot dot ...
:Thanks.
Old Oct 23, 2007 | 12:50 PM
HotMaxx02's Avatar
13.3 @106 mph.
60 ft: 2.1
Good #'s... But couldn't you get same/similar or even better #'s with a bolt on turbo kit??
AND you would have saved a lot of weight...
Old Oct 23, 2007 | 12:53 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by HotMaxx02
Good #'s... But couldn't you get same/similar or even better #'s with a Turbonetics turbo kit??
Explain, in technical detail.
Old Oct 23, 2007 | 01:30 PM
HotMaxx02's Avatar
I do not have technical detail...
Turbonetics "advertises" 300hp at the crank on their bolt on turbo kit including reflash and FMIC... All for about $3,000.
Obviously there are a lot of factors involved to translate that info into "whp" and how practical it really is, as well as how it performs. I have not seen a Dyno comparison to see the power curves where the 2.5 turbo reaches it's HP and TQ #'s to make it "usable", vs. the 3.5... and the 3.5 v6 is definitely heavier than the little 4-banger Just food for thought.
There were a few people talking smack at a recent meet about guys in Sentra 2.5 turbo's running high 12's low 13's... I cannot Validate that, just what i heard.
BUT i did get SPANKED by a 95 FWD 200sx 4-cylinder turbo running a 12.56
Old Oct 23, 2007 | 02:52 PM
NmexMAX's Avatar
dot dot dot ...
Exactly how much heavier is the QR vs the VQ?
Old Oct 23, 2007 | 03:08 PM
00SEMAX19's Avatar
I would think the heavier front end would help in traction.
Plus I'm sure it has much better low end torque than a turbo 2.5
More reliability without F/I
Just my thoughts without any real data.
Old Oct 23, 2007 | 05:42 PM
specvmatt's Avatar
the vq is 50 pounds heavier than the qr. which isnt much, especially if you add the weight of a turbo on a qr. almost no difference. i did it this way because its unique, much more reliable, and just plain badass. i dont have turbo lag, and if i want.. later on i can still boost. yeah qr's that are turboed are running 13's, i have yet to see 12's. but i like the all motor effect anyway.
Old Oct 23, 2007 | 06:22 PM
HotMaxx02's Avatar
I figured if you took the time and the Money to do the Swap you would have done your Homework...
And you DID.
Those were just my initial thoughts... no hard facts to back it up.
Welcome to the VQ Club
Old Oct 24, 2007 | 11:01 AM
specvmatt's Avatar
thanks
Miket2006
Mar 1, 2021 03:55 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
RWCreative
Sep 21, 2015 11:01 AM
97_GXE
20
Sep 17, 2015 08:12 PM
aminus21
Sep 12, 2015 04:53 PM
