alternator issues
Old Oct 15, 2007 | 02:00 PM
zheka's Avatar
alternator issues
I just installed a new alternator in my 2000 max. Everything works fine except it shuts off at high RPM (after 3500). At first my belt was loose, I tighten it up and got rid of that squeal, but the alty still shuts off. Besides taking it off and having auto zone checking it out, is there any sensors or relays that i should check out?
Old Oct 15, 2007 | 02:04 PM
jvienneau's Avatar
You might want to change the belt. Once they slip they can glaze the belt. No matter how tight you make it, it might still be slipping.
Old Oct 15, 2007 | 04:45 PM
Dayton100's Avatar
When I first changed my alternator I also replaced the belt, and a new alternator idler pulley along with it (b/c the bearing was about to break and it started making a diesel engine type noise). It worked like a charm but after 2 months, the car died on me, it wouldn't start back up. I had it towed to the stealership,
I have a 2kmax also so far I've changed battery, alternator (twice), and recently new starter motor. So far everything is good, but car at startup is not that good, the RPM drops really low. ]
Old Oct 17, 2007 | 08:08 AM
zheka's Avatar
changed the belt, the issue is still there, i need help
Old Oct 26, 2007 | 09:06 AM
zheka's Avatar
Update: now the alternator shuts off at regular cruising speeds and sometimes after I hit a bump. I have a dedicated route to school and it always shuts off at a certain area. It’s either a bump or a certain time. I turn the car off, then turn it on again and everything is fine. Any suggestions?
Old Oct 26, 2007 | 09:44 AM
hasei's Avatar
日産
Just out of curiosity without passing judgement, where did you buy the alternator?
Old Oct 26, 2007 | 10:21 AM
zheka's Avatar
S & G Imported Car Parts in ann arbor mi
Old Oct 26, 2007 | 10:49 AM
96-max's Avatar
sounds almost like a loose wire, might wanna go over everything and make sure its all tight. also you can put a load tester o your battery to semi check your altenator. good luck
Old Oct 28, 2007 | 06:11 PM
zheka's Avatar
how can it be a loose wire if I turn the car off and on again and the alty kicks in.
Old Oct 28, 2007 | 08:01 PM
Old Blue 66's Avatar
Dont know what year Max you have, but I bleieve there are two differnt Alternators....make sure you have the right one. Cant remmeber the difference between the two, but I k now there is a difference.
Old Oct 29, 2007 | 07:27 AM
zheka's Avatar
yea they checked it out and it had the same part # as the one before.
Old Oct 29, 2007 | 09:31 AM
gaby617's Avatar
i just installed a alternator on mines and im getting less power. the car pulls hard and it sounds like its pushing hard. the mechanic felt the need to disconect the coolant hose above the alternator and ac compressor and soaking it all. now i might have a bad ac compressor (hopefully not) or bad idle pulley.
Old Oct 29, 2007 | 10:48 AM
GodFather's Avatar
Made in Taiwan
Loose wires, check the battery terminals, make sure they are all tight. Then check your alternator to make sure the wires on them are tight.
If wires all checked out, then you may have a faulty voltage regulator or faulty alternator. I've gotten a faulty alternator from Autozone before, actually went through 3 of them within two days. Autozone alternators can be really off-spec sometimes.
-Peter-
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
mikeg75
Nov 30, 2015 05:12 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
