Hood Shaking
Old Oct 15, 2007 | 09:57 PM
maximo018's Avatar
Hood Shaking
For some reason at high speeds (60-80mph) my hood begins to shake up and down around the windshield wipers as though it were loose. I was told that this was adjustable but as to how I don't know. Anyone know of any solutions?
Old Oct 16, 2007 | 05:26 AM
ptviperz's Avatar
There are adjusters under the hood.
Old Oct 16, 2007 | 05:44 AM
zero2sixtyZ's Avatar
You embarrass me.
http://www.nissanhelp.com/Ownership/.../NTB02-005.htm
There is a TSB on that.
Old Oct 16, 2007 | 08:45 AM
jasonmax's Avatar
My hood isn't at the same level left and right. Left is good, but right fender edge is a little bit higher than hood.
Old Oct 16, 2007 | 09:31 AM
Froggmann's Avatar
It's probbibly the sprung welds discussed in the TSB mentioned above. Mine does it too.
Old Oct 16, 2007 | 09:39 AM
SoonerFan's Avatar
Cletus
fyi, weather stripping on top of headlights (were the hood meets) helps a lot. makes the hood more snug and reduces the air flow under the edges.
Old Oct 16, 2007 | 09:59 AM
DrunkieTheBear's Avatar
Turbo'd Saab
and where might i find this weather stripping? for all who may be curious
Old Oct 16, 2007 | 10:25 AM
SoonerFan's Avatar
Cletus
homedepot
lowes
autozone
advance auto parts
etc
etc
etc
Old Oct 16, 2007 | 10:33 AM
erikgeis's Avatar
Shaking hood brings back bad memories. When that thing flies off and smacks your windshield, it puts a real knot in your stomach.
Old Oct 16, 2007 | 10:40 AM
blkAEmax82's Avatar
Glory Glory Man United
Anyway to get that link to work .. I try www.nissanhelp.com and it didn't work either..
My hood as well looks like its going to open any minute while Im driving those speeds..
Thanks in advance
Old Oct 16, 2007 | 10:42 AM
SoonerFan's Avatar
Cletus
that site sucks
the site everyone on here uses for TSBs (from the sticky) http://maxima.theowensfamily.com/tsb/
the one for the hood http://maxima.theowensfamily.com/tsb/NTB02-005.pdf
Old Oct 16, 2007 | 11:16 AM
blkAEmax82's Avatar
Thanks Sooner.. !!
Old Oct 16, 2007 | 11:18 AM
SoonerFan's Avatar
Cletus
look at me....im helpful and stuff
Old Oct 16, 2007 | 12:33 PM
Iceman420's Avatar
(insert witty one liner)
The TSB states it's for 2001-2002.
I would imagine there is no difference on the 03's right?
Old Oct 16, 2007 | 04:28 PM
Turbo'd Saab
Originally Posted by perkman87
this is a great tip
your stay here is going to be short
Old Oct 17, 2007 | 10:16 AM
Xtr3m3X's Avatar
Reppin' the 216
You are right. '03s are the same.
Old Oct 17, 2007 | 10:29 AM
tonyw's Avatar
The TSB also lists some Nissan-made rubber parts that will help the problem. I ordered them (Total of about $10) and followed the TSB instructions. Most of of my hood vibration went away.
Old Oct 17, 2007 | 10:31 AM
bigjoe87865's Avatar
meaning some still there?... is it noticable?....
Old Oct 17, 2007 | 12:10 PM
Iceman420's Avatar
For the Canadians out there:
I just ordered these up from my local stealership and the cost was $25.00.
I'll report back as to whether or not it fixed the vibrations.
Old Oct 18, 2007 | 05:56 PM
philly786's Avatar
mine seems to vibrate but at the front, not the back near the windshield...if i push on it there is play...is that addressed in a TSB?
Old Oct 19, 2007 | 07:26 AM
Iceman420's Avatar
It is, there are three solutions in the TSB; Latch adjustment, rubber hood stop & headlight weather stripping, and broken welds.
If the vibrations are all up front then the likely culprit is the latch or the need to install the rubber stripping and bumpstop.
Old Oct 19, 2007 | 08:04 AM
Child_uv_KoRn's Avatar
Bad *** Newb
My popper for the hood got snapped off Why is it a plastic clip, honestly?
Nothin a little epoxy can't fix
Old Oct 27, 2007 | 12:23 PM
Iceman420's Avatar
Update: I installed all the weather stripping on top of the headlights. It did help the vibrations, but did not completely get rid of them. The hood stays pretty much still until I cross 120 km/h. At the higher speeds the hood still does vibrate a bit, but I wouldn't think it's enough to cause the latch to give way.
Old Oct 27, 2007 | 01:21 PM
Stardust's Avatar
F---ing Kangaroos
1 out of 14,0xx isn't bad
user 11122324
42
Jul 18, 2022 03:35 PM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
leatherneck
Sep 30, 2015 09:16 PM
dshinn
Sep 26, 2015 08:07 PM
