Sick of rattles from subs in the trunk
Old Oct 20, 2001 | 11:27 PM
Max_Vader_2K's Avatar
Ok Guys, I need some serious help I got a pair of subs in my trunk and there are some rattls from every dam place I can't find where they are comming from and its getting pretty sickning, for thoes of you with systems how did you resolve that issue?
Old Oct 20, 2001 | 11:51 PM
Y2KMaxGXE-R's Avatar
I got 2x10's powered by 500 watt amp. My license plate was the largest irritant. Later came out the tag rub through the paint. I touched that area up and sticked a tape so the plate doesnt come in contact with trunk lid. My 2nd prob I had my 150-lb box move all over my trunk. Was corrected for 30 bux, corrected for 30 bux.
Old Oct 20, 2001 | 11:58 PM
Ok.....
What about the rear deck because that were most of my rattle is comming from.
Old Oct 21, 2001 | 08:53 AM
chrislee8's Avatar
Look what I did.
http://www.sounddomain.com/member_pa...=128576&page=8
For your rear deck, just get into the trunk, lie down on the trunk floor, and put the stuff under the rear deck. A little bit harder, but very doable.
Good luck.
Old Oct 21, 2001 | 09:24 AM
thebigsadler's Avatar
Re: Look what I did.
for the rear deck i took a pillow apart and laid all the stuffing down underneath the deck and when i put the deck back on it was nice and tight and sealed.. my problem now is i am rattling the 3rd brake light (4th gen) out of place, it's kind of funny.
Old Oct 21, 2001 | 04:22 PM
wildr0id's Avatar
How did u correct that problem b/c mine is moving all around, and it is driving me nuts.!!!!!
Old Oct 21, 2001 | 06:50 PM
pushed it back in place, and pulled the power wire to the light REALLY tight, it's hard to get to now, but it doesnt move much.. another option is get some double sided tape..
Old Oct 21, 2001 | 07:17 PM
I took the car to the install shop. They drilled two holes in the trunk area (right below the rear deck) and two holes in the sub box. Then they took two metal stripes- the type of metal that you can hardly bend but won't break, and attached them on each side of the box. The downside is that I can't access the spare w/o taking all 4 screws out, plus all the wiring to the amp (fastened to the top of the sub box).
BTW anyone knows how to take off the rear window shelf, and how much those cost?
REDinLV
Aug 15, 2024 12:30 AM
user 11122324
42
Jul 18, 2022 03:35 PM
Redfox
Sep 28, 2015 10:41 AM
jerrod99_se-l
Sep 16, 2015 02:39 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
