NOISE From my Tokico Blue struts
Old Oct 19, 2007 | 07:56 PM
MaxiRacer's Avatar
I finally got my tokico blues installed with Eibach springs
but form the Rear/Right side the strut is making a noise as if a screw is loose (or like two small pieces of metal hitting one another) when I run over little bumps on the road.
The struts were bought used, and they looked in good condition.
Does anyone know what that could be
Old Oct 20, 2007 | 01:05 PM
Matt_01SE_20th's Avatar
Mounts. or just a loose bolt, check your torques.
Old Oct 20, 2007 | 04:30 PM
MaxiRacer's Avatar
Will get them check out this coming week,
but is it something i should be worried about
cuz i have been drive like this for 2 weeks was too busy to go and get it check out
Old Oct 20, 2007 | 04:33 PM
TurtleHead
Like MAtt said, it's probably the mount or the spring isolators (rubber hose thingy that wraps around the spring to prevent chaffing against the perch).
Old Oct 20, 2007 | 04:34 PM
SuperStasiu's Avatar
make sure the bushing that the spring sits in is properly put together also it could be just the spring setting. Lift the rear end up in the air then put a jack under the tire of the side thats making that noise. lift up and see what happens and look for what clicks
Old Oct 20, 2007 | 05:57 PM
spdfreak's Avatar
Just to be sure, the HP and Blues struts are the same thing? Correct?
Old Oct 20, 2007 | 09:49 PM
MaxiRacer's Avatar
great idea SuperStasiu, should of thought of that
thanks
Old Oct 20, 2007 | 09:50 PM
MaxiRacer's Avatar
oh, and thanks everyones for the help
Old Oct 20, 2007 | 11:30 PM
spdfreak's Avatar
I guess i'm correct because no one answered me.
Old Oct 20, 2007 | 11:42 PM
Shogunsc4's Avatar
Tokico HP = Blues.....same thing.
Old Oct 21, 2007 | 12:01 AM
MaxiRacer's Avatar
Yeah HP = BLUES
their both same
Old Oct 21, 2007 | 12:38 AM
spdfreak's Avatar
Originally Posted by MaxiRacer
Yeah HP = BLUES
their both same
Thanks guys.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
maxima-junky
Oct 7, 2015 06:13 PM
Need help
23
Oct 2, 2015 08:56 AM
