Ypipe for a 5th gen
Old Oct 21, 2001 | 05:11 PM
BigDogJonx's Avatar
Ypipe for a 5th gen
MAN, I want to get a Ypipe, but I heard the Catmann and the Stillen is like $350-400.
Everyone talking about this new company called WarpSpeed that is gonna make them cheaper......... How much anyone know what the cheapest one is now if the WarpSpeed one is not out yet?
I want to buy in like 1-2weeks.
Dixit
Old Oct 21, 2001 | 06:06 PM
UMD_MaxSE's Avatar
Got Bent?
I think warpspeed makes two varieties... non-mandrel bent and mandrel bent SS.... I think their cheapest is like $199... but they don't make anything for the fifth gen yet.
Old Oct 21, 2001 | 06:30 PM
Paul6speed's Avatar
There is yet another. Budget Y. Eben from the DC Maxima club got one. It worked great for him. He ran a 15.3 with the Y, cone intake and ECU.
Old Oct 21, 2001 | 07:25 PM
BigDogJonx's Avatar
Damn DC Metro people representing on this post, UMD in Columbia, Paul in Potomac, Me in Laurel.
Well, Paul, Where can I get this Budget Y pipe? And is it comparable to the Catmann or Stillen?
And UMD, what is the difference in the bent mandrel or nonbent ones?
Dixit
Old Oct 21, 2001 | 08:03 PM
got rice?'s Avatar
Dixit
Mandrel bends are smoother and result in less turbulent exhaust flow and higher exhaust velocities. Non-mandrel bent pipes have kinks and irregularities, causing some turbulent flow and reducing the velocity.
Old Oct 21, 2001 | 08:17 PM
rubman's Avatar
Re: Ypipe for a 5th gen
Dixit
Bought my Stillen y-pipe about two weeks ago, had it installed. Some ******* ran into my rear bumper, the car has been in the body shop for two weeks. It will be out tomorrow. First mod I did was Stillen hi=flo intake. THE Y-PIPE IS THE BEST MOD FOR THE $$$. Believe me when I say 2 u, Stillen hi-flo. JUST DO IT. Everyone that has done it on this board just loves it. Best mod ever. Next on my list was Greddy Evo, one of the guys here had it installed then had the car dynoed, only 6 Hp increase. The convincing story for me was when someone else dynoed car after stillen hi-flo intake installed, eight hp increase. When he installed the Stillen y-pipe, twelve hp increase.
Do it asap, enjoy. U paid a lot for ur car, buy the best u can afford for the car.
Old Oct 21, 2001 | 11:22 PM
woosh's Avatar
Can someone with some experience on this install give some sort of level difficulty for the Y-pipe mod. Is it ok for the not so mechanically inclined to attempt? Does it involve expensive tools and any other hoo-ha?
Can a 2K/2K1 w intake + Y-pipe outrun a 2K2 no Y-pipe?
Hey BigDog what's up man? Let us know if you track this budget Y -pipe down and if your research says you should get it or not. I've been wanting to do this but 2 things holding me back, the price and the bees in a can noise that Kev mentioned.
Old Oct 21, 2001 | 11:34 PM
yongjun's Avatar
WSP isn't the best set of pipes to get
PM me for more info.
Old Oct 22, 2001 | 06:24 AM
UMD_MaxSE's Avatar
Got Bent?
You can do the y-pipe install yourself if you have a few tools. Deep sockets, extensions, and swivel joints are needed. A breaker bar will also help. It will take a bit of tim though. Getting the stock pipe off could be tough.
Old Oct 22, 2001 | 07:56 AM
woosh's Avatar
I forgot, one more important thing that makes me hesitant about the Y pipe, the emissions test. Has anyone failed it because of the Y-pipe.
I read on here that all you have to do is make sure the car is properly warmed up. Just want to know if anyone has had problems passing the emissions test because of the Y-pipe
Old Oct 22, 2001 | 08:08 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Don't worry about emissions if you're not going to Nissan to get smogged. Almost no one would notice... except for Nissan.
BTW, add anti-seize to the list. Use it on the nuts and bolts when you install the new y-pipe.
Old Oct 22, 2001 | 09:01 AM
madmax2k's Avatar
Getting the stock pipe off does take a bit more time than putting the new one on. But, the entire job shouldnt take more than 1.5 hours if you just cruise along.
You will need the following:
Rachet,
10 mm socket,
12 mm socket,
13 mm socket,
14 mm socket,
universal joint (to get at 2 of the 13 mm nuts holding the rear Y- section to the exhaust manifold),
8 or 10 inch extension,
7/8" open ended wrench (to remove O2 sensors)
And, of course, a good jack and 2 jackstands. (Dont work under the car with jackstands!)
Antiseize on the O2 sensor threads is also a good idea, just dont get any on the sensor itself.
You can usually re-use the compression ring gaskets on the downpipes and the steel gasket on the catalytic converter without a problem.
Old Oct 22, 2001 | 09:07 AM
Y2KevSE's Avatar
13mm socket? My nuts were all 14mm.
7/8" ~ 22mm
Hehehehe, I said "my nuts"
Old Oct 22, 2001 | 12:32 PM
Keh mon's Avatar
7/8" ~ 22mm
I dunno what's up with you and sprint lately talking about your junk. But I'm just gonna step to the side and not notice.
Old Oct 22, 2001 | 12:33 PM
Keh mon's Avatar
Your nuts were only 14mm? Wow I'm sorry to hear. I had to use a 2' wrench for mine.
Old Oct 22, 2001 | 12:46 PM
UMD_MaxSE's Avatar
Got Bent?
I don't think we are talking exhaust anymore
Old Oct 22, 2001 | 12:52 PM
BigDogJonx's Avatar
Yeap dont you love how a post from one end to another?
Old Oct 22, 2001 | 01:05 PM
UMD_MaxSE's Avatar
Got Bent?
yes
Old Oct 22, 2001 | 01:27 PM
got rice?'s Avatar
Rachet,
10 mm socket,
12 mm socket,
13 mm socket,
14 mm socket,
Liquid Wrench to soak the bolts before trying to remove them... also a good idea !
Old Oct 22, 2001 | 11:20 PM
ChillWill2000's Avatar
any luck?
Hey BigDog.... did you ever find where to get a good y pipe for a good price? Im in the same boat you are right now, I gotta get one but I really dont wanna pay 400 big ones!!! Im sure it would be worth it but Im always down for savin a few dollars ...
Old Oct 22, 2001 | 11:51 PM
BigDogJonx's Avatar
Re: any luck?
Well you can obviously see from this thread, it went from Y-pipe to God knows what. So I have gotten no info that will help.
Still looking.
Old Oct 23, 2001 | 04:02 AM
kafene's Avatar
ECU for the 5th gen?
i didn't know there were any ecu's available for 5th gens. please correct me.
kafene.
Old Oct 23, 2001 | 04:58 AM
UMD_MaxSE's Avatar
Got Bent?
Re: ECU for the 5th gen?
kafene.
Old Oct 24, 2001 | 03:39 AM
kafene's Avatar
Re: Re: ECU for the 5th gen?
Old Oct 24, 2001 | 05:00 AM
UMD_MaxSE's Avatar
Got Bent?
Re: Re: Re: ECU for the 5th gen?
hmmm... post didn't come out... anyhow, Eben has a '95 maxima.... he has an ECU for that.
MAXSE5SPD
Sep 17, 2022 04:00 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
220k+ A32
Sep 23, 2015 03:38 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
