new struts get rid of clunking noises
Old Oct 31, 2007 | 03:33 PM
Martin's Avatar
Problem: clunking noises from front end, particularly drivers side. New stabilizer bar rubber mounts were installed. No better. New stabilizer bar support links (the short ones with the bushings on both ends) replaced. No better. Finally out of frustration, and with some clues from this group I replaced both front struts and voila - quiet has returned to the front end. The front end was getting kind of mushy, with some bottoming out on big bumps, but I couldn't figure out what that had to do with the clunking noises. The struts showed no signs of failure - no oil leakage, etc. Even when I took the first one out and pressed on it it seemed normal, just a little softer that the new KYB's. Anyways, maybe this will help a fellow owner with a similar problem. 2000 SE 5sp with 140,000 km.
Martin
Old Nov 1, 2007 | 08:06 AM
Old Blue 66's Avatar
If you never replacedthe struts in 140K, Im not surprised. I think theyre only supposed to last about 75K.
Old Nov 1, 2007 | 10:16 AM
02Maximan's Avatar
yep mine were clunking like that and when I took em off both of the fronts had hardly any compression left and I'm at 69,000. Its all good now though with my new Blues!
Old Nov 1, 2007 | 11:14 AM
vball_max's Avatar
Martin, do you have less bang when you hit big bumps now that you have replaced the struts?
I am looking to replace my struts and wondering if it will take care of the hard hits.....
Old Nov 1, 2007 | 11:29 AM
gxe2se's Avatar
how did you decide on the blues vs the illuminas? I know that blues are cheaper, I was wondering if the illuminas ride better with the stock springs (gxe), with setting at "1" vs. blues HP.
Old Nov 1, 2007 | 01:46 PM
Torgus's Avatar
i hate blues. anything rides better then them.
Old Nov 1, 2007 | 02:06 PM
miksen's Avatar
FU, FU, FU, You're Cool..
+1
i have blues and eibach and F'in hate the way my car rides and the bumps are so harsh I feel like I am riding a solid supension
Old Nov 1, 2007 | 02:45 PM
reeloop's Avatar
I have blues and I am very satisfied with the ride quality
with 17 Inch wheels they are soft, as soon as I put on the infiniti 18's the ride got much worse though.
Old Nov 1, 2007 | 09:18 PM
Martin's Avatar
Kgallerie,
All is well as far as big bumps go. It needs to be remembered that the struts work hard due to the big (heavy) wheels and heavy front end. Big bumps will always make some noise, even with the vibration isolation built into the front end.
Martin
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
maxima-junky
Oct 7, 2015 06:13 PM
