motor mounts
Old Nov 18, 2007 | 09:24 AM
dizmax96's Avatar
motor mounts
hey everyone. jus wondering if racingline mmi will work on 02-03 max's. or do i have to get energy suspension mm bushings from cattman? anyone that has these please chime in. thanks a lot guys
David
Old Nov 18, 2007 | 04:00 PM
dizmax96's Avatar
anyone? come on.. someones gotta know.
Old Nov 18, 2007 | 04:05 PM
zero2sixtyZ's Avatar
You embarrass me.
Just wondering, why would you want just MMIs versus a full mount replacement?
Old Nov 18, 2007 | 09:32 PM
dizmax96's Avatar
well i havent changed mines and i wanna get rid of wheel hop. and its jus something to do to the car. i dono if the ES bushings are jus inserts or what. wanted to know if there was a difference in the ES bushings and racingline MMI, and if the racingline MMI would work on a 5th gen since the its made for 6th gen. my mount isnt broken or anything. when changing the mount your not changing the metal part anyhow.
Old Nov 19, 2007 | 05:08 PM
dizmax96's Avatar
booo no ones relpying. come onn.. maybe i should jus ask irish.
Old Nov 19, 2007 | 05:42 PM
SoonerFan's Avatar
Cletus
or look around for the answer
Old Nov 21, 2007 | 09:51 AM
joebangaa's Avatar
Show us a full mount replacement please.
Old Nov 21, 2007 | 09:54 AM
MaxBoost925's Avatar
Drug Money
FYI, I have the OG Place Racing motor mounts, I still get wheel hop FTMFL.
Old Apr 6, 2008 | 09:55 AM
TAZ's Avatar
TAZ
Theap bump........sorry for the late post............
Racingline inserts will install in seconds once the mount is removed vs. the ES insert which needs to be pressed into you stock mount with a hydraulic press, Actually it's the stock rubber inside that needs to be pressed out or cut away. Either way it's more time consuming and more labour intensive.
I've not tested the Racingline inserts on a 5th gen but I've looked into it and I know the front mount is the same. not sure about the rear. If anyone wants to test them send me a PM and we'll arrange a deal.
Old Apr 6, 2008 | 10:02 AM
RacerX1320's Avatar
ES mounts are perfect, took my hop out completely. If you launch hard itll just sit there and fry em.
Old Apr 7, 2008 | 08:34 PM
dizmax96's Avatar
finally some answers.. haha man i made this post so long ago. taz did you ever get my email about the rear links that started to make noise after install? so the front MMI will work and the rear is a maybe? now i need to look into install how to. im guessing the whole mount has to come out before install the insert correct? wanna get this whole engine shifting business outta the way soon.. its become somewhat annoying... hit me back TAZ
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
