Front Sway bar diameter on 5.5 SE
Old Nov 21, 2007 | 06:08 AM
Vadim's Avatar
I need to get new front sway bar bushings. They come in 22mm and 23mm. I have a 2k2 SE. I remember SEs were suppose to have a thicker swaybar. Can anyone confirm that i'd need 23mm bushings? Any recommendations on where to buy? I found ES bushings on ebay for $22 + $7 shipping.
Old Nov 21, 2007 | 03:08 PM
Orgullo's Avatar
$$ Ballin on a Budget $$
Auto Zone has them for 19.99.
2002/2003 GLE GXE 22mm bushing set.
2002/2003 SE 23mm bushing set. As per energy suspension and AZ's website.
I'm about to order them too.
http://www.autozone.com/N,14600205//...eResultSet.htm
Old Nov 21, 2007 | 08:51 PM
Scottwax's Avatar
That's Mr. Detail to you
Rubber or urethane?
Old Nov 22, 2007 | 06:09 AM
ghostrider17's Avatar
I'd like to replace mine, but after looking at the bushing mounts -- I'm affraid I won't be able to get them swapped without a SERIOUS hassle!
gr
***Scottwax: U R E T H A N E. ***
Old Nov 22, 2007 | 07:57 AM
Stardust's Avatar
F---ing Kangaroos
Learn to find your own information.
Not every question requires a new thread.
Old Nov 22, 2007 | 12:12 PM
Matt_01SE_20th's Avatar
you need the 23mm. anyone who is wary of doing this swap shouldnt be changing their own oil. This was the easiest job ive done in a LONG time. looks much more difficult than it is.
Old Nov 22, 2007 | 12:51 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
replace them with urethane... worth the hassle and money
Old Nov 22, 2007 | 04:37 PM
Scottwax's Avatar
D-bushings are amazingly easy to change out but if you swap in urethane bushings, you should probably do the same to the end links (depending on design-haven't looked at the ones in my Maxima yet) or you are wasting your time.
Old Nov 23, 2007 | 08:58 AM
I guess maybe i'm just intimidated by the huge bolts and the lack of space to maneuver around that area.
If anybody has the toque specs for the sway-bar bushings AND the end links, that'd be appreciated as well -- while we're at it.
no worries then - I should be able to handle it! Thanks for the confidence booster boys!
gr
Old Nov 23, 2007 | 09:30 AM
Scottwax's Avatar
I've never used a torque wrench when tightening the bolts for the D-bushings or end links, I just make sure they are tight. Never had a problem with them loosening up.
Old Nov 26, 2007 | 07:59 AM
Vadim's Avatar
Thanks everyone! I ended up buying from Ebay. Tried AZ, it wouldn't let me order it online.
Old Nov 26, 2007 | 09:01 PM
irish44j's Avatar
retired moderator
asked and answered.
MAXSE5SPD
Sep 17, 2022 04:00 AM
The Frye
Sep 2, 2021 11:03 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
