whats the best way 2 replace alternator belt..
Old Nov 29, 2007 | 07:15 AM
vq35's Avatar
1. i suppose take off the passenger side wheel..to start..am i correct?
2.take off tensioner pulley?
Old Nov 29, 2007 | 07:32 AM
NmexMAX's Avatar
dot dot dot ...
Jack car up, remove wheel, remove plastic shrouding, loosen tensioner pulley bolt on pulley, loosen tension from under hood (tension adjustment bolt), remove belt, repalce belt, Budweiser.
Don't take the pulley off, you don't have to.
Best way to understand this, open hood, jack car up, take wheel and plastic shrouding off, take a good look around, pretty self explanatory.
Old Nov 29, 2007 | 07:35 AM
vq35's Avatar
thanx...lol@budweiser...that definitely would be good after completion
Old Nov 29, 2007 | 11:21 AM
vq35's Avatar
mission complete...everything is running smooth........btw nmexmax i did it xactly how u said it was easy,but i had to fix the tension by loosening the alternator and make it perfectly tight..
Old Nov 29, 2007 | 11:46 AM
ScottS's Avatar
Thanks for this. On my list of things to do as well.
Old Nov 29, 2007 | 01:12 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by vq35
missin complete...everything is running smooth........btw nmexmax i did it xactly how u said it was easy,but i had to fix the tension by loosening the alternator and make it perfectly tight..
It can be done by loosening the holy hell out of the adjuster bolt under the hood, so you it's not mandatory to do what you did, but I suppose it might make it easier.
Glad we could help. I need to tighten my PS belt
lowpost99
Oct 26, 2025 06:53 PM
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
TheMafia
Sep 4, 2015 08:26 AM
