Front passenger seat Prob
Old Dec 1, 2007 | 12:15 PM
Drstove's Avatar
Hey guys i was cleanin out my max this mornin and a ran the seat all the way forward to clean out underneath it then i ran it all the way back once i was doen. Here is the prob i have now it wont move forward of back but the tilt part works fine anybody got any suggestions as to what could possibly be the prob?
Old Dec 1, 2007 | 12:18 PM
SoonerFan's Avatar
Cletus
check the connections
Old Dec 1, 2007 | 04:39 PM
jasonmax's Avatar
I have an extra plug under my driver seat. Will that be the heated plug?
Old Dec 3, 2007 | 10:06 AM
gotcha640's Avatar
I had the same prob but with drivers seat. It's probly not the connection. The screws that run the seat forward and backward are either tapered from the factory, or get tapered over time. Either way, the seat can just get jammed on the screws. I can usually just bounce on the seat a little while holding the switch and it will move. Don't just push straight back, you're trying to jar the ball screw loose. You might have to work at it a little. The first time it happened, I didn't realize I could fix it like that, I took the seat out and undid the screw. If you have to do that, just make sure you get right and left mounts back to the same position. Let me know if you have any problems.
I had hoped to find a pic of the underside so I could point out the problem, no luck. If anyone takes their seat out, please post a pic. I'm sure this is a common problem. My brothers max does it too.
Old Dec 3, 2007 | 11:34 AM
Ricfutures's Avatar
My right side passenger seat has not moved in Months I will try the "bounce" solution on my lunch break. Fortunately it's stuck in the furthest back positon as well.
Old Dec 3, 2007 | 12:11 PM
2002 Maxima SE's Avatar
I've had that happen twice on my 2002, but with the recline. It is something wrong with the switch. If you play with it (sliding it front-back-front-back quickly) the seat will eventually move and return to normal.
First time it happened, my wife was in the car and reclined while I was in a store. I came back to find her frantic, thinking she had broken the car. The seat would recline, but then not go back up. She reclined it more, but the seat would not move in the opposite direction. Finally she had the seat fully reclined.
Jiggling the switch (as mentioned) returned it to normal operation.
Old Dec 3, 2007 | 12:14 PM
I'll post a pic when I get home. When my driverside seat locked up, it was because the washer in front of the rubber end point came loose, and chewed up the rubber end point. Eventually burning out the motor. There is a TSB out for this, but it doesn't state the exact problem...just gives a replacement motor part number.
Old Dec 3, 2007 | 12:42 PM
00SEMAX19's Avatar
I had this problem, but for me it was a penny stuck in the track that jammed it up. It happened when I went all the way back for cleaning as well
Old Dec 3, 2007 | 01:30 PM
Old Dec 4, 2007 | 03:38 PM
MSchumacher's Avatar
i have the same problem with both my driver's and passenger's seats..thats why i never pull it all the way back... jus give it a lil push while holding the buttion..
carguy96
20
Feb 6, 2021 06:21 AM
homeyclaus
Sep 3, 2015 06:15 PM
spidgeon
Aug 24, 2015 11:14 AM
george__
Aug 18, 2015 07:06 PM
follyburr
Aug 7, 2015 09:50 PM
