how do i remove the scrwes on the bose unit
I broke the heads on 3 screws and had to drill thru them - was a bit of a pita, but did not take much time. replacements from home depot are cheap.
I would do it by hand with a screw driver that fits really tight...
BTW, I also broke one screwdriver bit when i tried to use my 18v cordless drill
Unfortunately, after stripping a couple of the screws out I had to resort to a drill. I sugguest what the others have stated and use a good fit phillips driver and quit a bit of force. I was lucky enough to get the majority of them out this way.
Good luck!
Good luck!
they have some sort of locktite on them. just crank em forward a 1/4 turn before you start to unturn them and they come off easy. also this is in the wrong section of the forum.
idiots? Don't generalize everybody that posted before you!
I had same situation on my 4th Gen and got 4 out by hand and the other 4 I used a cordless impact screwdriver - after hammering on it for a few seconds they all came out easily (last one broke the bit though - Craftsman tool w/ cheap chinese bits, same ones from my ghetto black&decker set).
Sorry that was lame.
